SOURCE: change language
not sure you can????
Anyway to get into service mode,
open front door
bottom left next to green knob there is a pinhole
insert paper clip and push on switch
you should be in service mode
if not you must cheat the front door while it is open (folded paper in slot will do)
then go through the steps
once in service mode you should be able to scroll and check for language
SOURCE: printing on Canon NP 6035
I check www.usa.canon.com and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
SOURCE: aaa
Here ya go:
What you will see
The printer display is not in the required language.
What to do
To change the language on the display back to the required language, do the following:
Steps Action 1 Power the printer off and back on. 2 Press the down arrow button () four times. 3 Press the button once. 4 Press once. 5 Press once. 6 Press once. 7 Press the left arrow button () or right arrow button () until you see the desired language. 8 Press the return button (). 9 Press once to save the new setting
SOURCE: canon np 6035 saya tak menyala tombol start di
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
