Question about HP Office Equipment & Supplies
How to change cartridges in my C4480 printer - HP Office Equipment & Supplies
    Problem Solver:
  • 33 Answers
Try going to the manufacturer's website, or reading the instruction manual for your printer. There should be pictures and detailed explanations in there.
~hope this helps !
Posted on Dec 14, 2008
4 Suggested Answers
don_farr
  • 1018 Answers
SOURCE: HP C4480 printer.Refilled the cartridge,how do I tell the printer
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Posted on Nov 02, 2009
SOURCE: HP photosmart C4480 printer cartridge incompatible error
Well....I solved the problem......bought a new Canon printer!!
I tried everything...unplugging, cleaning everything that was mentioned above. I was onto HP online support several time, but they were absolutely no help at all...they basically told me that the cartridge must be damaged or ink dried up and to buy a new cartridge to see if the error persisted.....I don't think so!!!
I will never by HP again after having issues with the last two I have had. I love my new Canon printer it is EVERYTHING that HP wasnt.
Posted on Jan 16, 2010
rebell26
  • 86 Answers
SOURCE: Hp PhotoSmart C4480 printer all of a sudden
You will need to contact HP and request a "regionalization reset". To perform the reset you will need access to your computer and printer as well as a set of cartrdiges for your new region while on the phone with HP. Once the region has been reset the original (US region) cartridges will no longer work in your printer.
Posted on Feb 12, 2010
How to change ink cartridge in hp photosmart c4480?
Please go to shop of printers and said to shop keeper please change my printer's ink.
Mar 08, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
What is the problem with my c4480 printer when the light is blinking
In case it's a problem with the cartridge-printer connection, try cleaning the cartridges (both on the cartridge and on the printer), details is in the link below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01442936&tmp_task=solveCategory&lc=en&dlc=en&cc=ie&lang=en&product=3418705#N263
thanks
Nov 26, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
C4480 all in one screen has an "incompatible print cartridge[s]" message. The same hp cartridges have been in the printer for a month, then 2 days ago get this message
Did any one remove the cartridge to check it, if so will need to initialize it to a used one otherwise check the numbers on the cartridge to ensure none were swapped.
Oct 15, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Don
Nov 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Want to change cartridge on hp PHOTOSMART C4480
Look at the front of the printer and you will see a slot in the center of the front. Reach into that slot and pull forward. That will open and allow access to the cartridges on the right. Grab the cartridge you want to change and pull down slightly and out. Remove the tab covering the connections on the new cartridge and reverse the procedure to install.
Jun 04, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Change ink cartridges in HP photosmart C4480
4b148f6.jpg2646f7c.jpg435ef67.jpg1d4768c.jpgbf522ec.jpg1995c7e.jpge4d2be6.jpgHope this helps..
Sorry about the format, I could only do screen captures of the PDF, in order to show you the pictures as well as the text. I don't think it would have been understandable without the picture guide..
Chris (ziraffa)
Dec 11, 2008 | HP PhotoSmart C4480 All-in-One Printer ...
46 people viewed this question
Ben Johnson
