Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Hot Tumble When the macjine is in hot tumble it seems to bee too hot and even after 2 hours clothes are not dry but are very hot
  • 247 Answers
Sounds like you've lost the coolant water flow to the condenser. Make sure the cold water supply is turned on, and the hose is neither trapped nor kinked. If that draws a blank, the most likely problem is the solenoid valve which controls the coolant flow. Unfortunately, on this machine the valve is in a cluster of three - making it a bit more expensive to replace on spec. The valve is the great lump of stuff on the other end of the threaded stub of pipe you screw your inlet hose to. It has three outlets, each controlled by a solenoid. In all likelihood, one of these solenoids has burnt out - they often do. If you're not confident with electricity, I'd advise simply replacing the valve and hoping that will do the job - more likely than not, it will. (shop around - a couple of minutes' searching on the net showed prices varying between £33 and £58). If you're reasonably confident messing about with electrics, then unplug the machine and use a multimeter to test the coil resistance of each of the three solenoids in turn. You'd expect them all to be within 20% or so of each other. If one is much higher than the others, then you've got a smoking gun, and it really is time to buy a new valve. If you are very confident, you could make up a lead with a 13A plug on one end and a couple of push-on connectors on the other - then use this to apply power to each solenoid in turn, checking for movement of the solenoid armature and water flow. This is a substantially more risky proposition, so only try it if you're confident you know what you're doing - and even then be very careful. If after all that you're still sure the valve is OK, then you need to watch the thing in operation. If you can see the valve open, but there's no flow then you may have a blockage (unlikely, as the valve has an inlet strainer which also serves the main fill). If there's no movement, then you may have a timer or wiring problem. A.
Posted on Mar 11, 2007
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Hotpoint A1400WD Washer Dryer
Check your dryer vent (probably outside) to be sure something or a kid hasn't flattened it, making it not vent moisture properly. Replace the vent or pull it back out so the damper door will open.
Feb 26, 2014 | Dryers
Hotpoint ultima tcd980 condenser tumble dryer not drying properly
this sounds like one or two of your stats (tod) for short have gone if you need more help get back ok
Oct 22, 2012 | Washing Machines
The dryer does not get hot, it seems to tumble and do everything else ok but it is not getting hot or drying the clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | LG DLE2514 Electric Dryer
I've got a zaussi tce7276w condensing tumble dryer and its taking 3-4 hours to dry a load of clothes it doesn't seem to be getting hot inside i've cleaned all the filters and checked the back for blockages...
yu may have a bad heat switch but it sure sounds like ur dryer vent is kinked or clogged double check better yet unhook it from the back of the dryer and dry a load of clothes if better ur problem is in that vent
Feb 24, 2010 | Dryers
No tumble action, belt seems fine
the belt has to be replaced
May 12, 2009 | Dryers
Dryer won't dry
Remove the rear connecting vent and try it again.
If it dries correctly...and it probably will. , clen the connecting vent and the vent in the wall.
Mar 27, 2009 | KitchenAid Dryers
No heat from my tumble dryer
Presumably the motor and fan are working.
Check filter, and if it is vented with a hose, make sure it is not blocked with fluff. if all seems to be o/k, then the heating element is probably faulty.
Please leave good feedback if this helps with your problem
Nov 26, 2008 | Dryers
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
77 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
