Question about GE 24 in. Profile PDW9200J Built-in Dishwasher
Power outtage blues
Dishwasher worked fine until it was in the middle of the drying cycle and we had a power outtage. When power came back on, dishwasher now makes an ringing alarm sound that is very annoying. Keypad is dead. Nothing else seems to work. Tried to put it in test mode via the instructions found on the tech sheet. Nothing happens. Only way to stop the ringing sound is to shut off circuit breaker. Any ideas? last night we had a power outage and when the power came on our G.E. Profile PWD9200 dishwasher stated making a high pitched sound and also there is no display on the touch pad.
  • 706 Answers
Hello daniedag,
Unfortunately, your dishwasher may have experienced a power surge when the power went off and dmaged some internal components or the control logic. There is no way of knowing the extent of your problem without a thorough diagnostics to it. It could be something as simple as a circuit borad component, stuck relay but this kind of repair is probably not something you would want to tackle yourself unless properly trained and with the proper test equipment. If you have homeowners insurance, it may cover the damage.. If not, then a service call is most likely required. Here is a link to the GE website for yopur dishwasher but your model is not PWD9200 and IS PDW9200 http://genet.geappliances.com/DocSearch/Dispatcher
Hope this helps..
Regards,
Rick
Posted on Dec 13, 2008
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
Hi, I have an BOSH dishwasher SGV4313gb/17. It is about 8yrs old and has worked fine until last week when it did not complete its cycle. Have reset and it seems to complete cycle but I don't think it...
Are you using a rinse aid? if so and teh dishes are still not drying properly, try adjusting the setting for the rinse aid dispenser. Open the door of the dishwasher, open the flap where you pour in the rinse aid and look for the cirlce with the arrow and nunbers on it. If it is set low (1 or 2) try turning the arrow to a higher number. If that adjustment doesn't work, increase again and again until the dishes are dry.
Jan 05, 2011 | Bosch Dishwashers
Maytag Quiet Series 200 dishwasher doesn't start
The electronic control panel has gotten wet and needs to be replaced (about $200 for parts plus about $200 for service call/labor) I just had mine replaced about 10 month ago, stopped using the type of dishwasher soap I had based on Maytag Service staff recommendation, stopped using hot wash to prevent high condensation at the door and now its broken again and in need of a new control panel again. You may be money ahead to go buy a new dishwasher that does not have the plastic encased control panel at the top. My understanding is the control panels are poorly engineered and made for most dishwasher manufactures by one of the mega electronic/appliance companies.
Dec 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Turns on for 30 seconds, then turns off,not let me cancel/drain?
unit is in sales demo mode.
push in less than 3 seconds:
High temp - heated dry - heated dry - high temp - heated dry - heated dry
to switch demo mode off
Feb 23, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Apr 06, 2008 | Asko D1776 Stainless Steel Built-in...
Frigidaire Ultraquiet III
hi there,
can you supply me with the exact model # off your d/w please?
Mar 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
GE 24 in. Profile PDW9200J Built-in Dishwasher Logo
398 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
