Question about Vivitar DVR-550 DV Camcorder
Camera is borken for the second time.
Unit will not turn on, checked everything out as far as the basics. product was sent to the company once, got it back, was ok for approximately three months and now it is back to the way it was before we got it fixed.
  • 470 Answers
You will need to reprogram your camera,, go for the unit software master,, the problem of it is the program!,, reformat it, go to the technician, and additionaly recheck if ther is a virus or not.
Posted on Dec 13, 2008
    Top Expert:
  • Vivitar Master
  • 70,346 Answers
I would send it back U aren't unlikely to get the info to repair it here, they most likely did not replace the part that was causing the problem, also are u skilled enough to take it apart, which by the way will void your warranty.
  • yadayada
    yadayada Dec 13, 2008
    it should read are not likely
  • yadayada
    and so starts the useless answers from some of our experts
  • 13,433 Answers
Have you tried taking the battery out and connecting again? Does the camera turn on?
Is the camera under warranty and did you get it warranty repaired or was it outside of warranty?
Its probably the same fault as last time.
  • Vivitar Master
  • 19,396 Answers
Contact back the company and ask for a full replacement, the camera has not been repaired.
  • Ginko
    Ginko Dec 13, 2008
    Contact the company by phone, and tell them that shortly after the repair you got the same fault. That means that the reapair from last time had been ineffective, insist to get a full replacement.
  • Ginko
    Ginko Dec 13, 2008
    I do not think you can fix this with battery in/out. If the camera does not show any sign of life, then the problem is the ribbon cable that connects into the mainboard and carries power from batteryes, or from AC adapter.
    If it was just the cable, it would have been replaced when you have sent the camera in for repair.
    More likely the connector where you hook in the cable, that is located on the main board, is defective, and mainboard had not been replaced, as moving the cable it restarted to work.
    That is a common situation, and may be the reason why the camcorder had gone faulty again.
    If the camera was still under warranty when you did the fiorst repair, send it back and ask for a replacement. If warranty is expired ask a new repair, they may need to replace the main board.
How can I repair the lens error message on my Nikon Coolpix S6800 camera?
Copied from Nikon's Service & Support Page:
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
To find your local Nikon authorized service agent Click Here.
We apologize for the inconvenience and will do everything we can to repair your Nikon camera as quickly as possible.
Apr 24, 2015 | Nikon Cameras
How to repair my camera giving a lens error
Apr 24, 2015 | Nikon COOLPIX S6800 Digital Camera Black
Camera beeps 3 times and then turns off
Hi there when you turn it on shake the thing like mad this works for my pentax optio otherwise it starts then turns off after 5 seconds, Also try to reset to factory settings Best REgards Alex (Hairydog)
Aug 10, 2009 | Cameras
Cannon powerShot S2
Unfortunately this issue is most commonly caused by an electrical failure with the camera's power unit. Sometimes a hard reset will work, though I'm not sure if permanently.
Usually the solution is to call Canon's tech support and have the unit sent in for service. To give the reset a try however turn your camera on and immediately press and hold the Menu button for approximately 7 or 8 seconds (until you get a Reset Camera message). If you can get this far, do the reset and then power down the camera.
Then remove the memory card, the batteries and the date/time battery unit (a small rectangular door located inside the main battery well). Once all batteries are removed, turn the camera's power switch into the on position. Wait two minutes then press the power button as if turning it off. Then replace all batteries and the memory card.
Turn the camera back on and immediately set the time and date.
Turn the camera off and on a few times and take a few shots if possible. This works in about 25% of the time. If it doesn't and you have confirmed that the battery itselef is good (by placing it in another unit typically) then the camera will typically have to be sent in for a service repair.
Hope this helps.
Sincerely,
HeavyDLB
May 25, 2008 | Canon PowerShot S2 IS Digital Camera
No power to control unit
Basically your service did not add anything I had not tried already. I had to send the product back.
I would like a refund.
Apr 10, 2008 | Audio Players & Recorders
Blured Pictures
When you sent the camera in did they give you a diagnosis? Even set to macro it shouldn't affect wider angle pictures. My money would be on a fault with the autofocus, sony probably should have replaced the unit. I wouldn't give up on sony though, every cybershot i've used (which quite a few) has always given good results and never had a fault. I agree i've seen plenty of dsc w30's/35's/50's/55's etc models on ebay with breakdown problems of one sort or another, but all manufacturers have problems.
Jan 01, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Samsung camera not turning on.
First make sure you batteries are strong.
Then this is not a great solution, but try this. 1) Remove the battery. 2) Hold down the power button and wait 30 seconds...but keep holding the button. 3) After 30 seconds and while holding the button down insert the batteries and then close the compartment. It should come on.
I managed to duplicate the problem by opening the battery compartment with the camera turn on and then if I put them back it would turn on and the lense does not retract.
Good Luck
Dec 25, 2007 | Samsung Digimax D53 Digital Camera
Powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Nov 15, 2006 | Lowrance LCX-19C GPS Receiver
Not syncing
Could be a bad cable, bad firewire card in computer, or the unit is damaged.  Might want to connect the unit to someone else's computer with a new Firewire cable.  If this doesn't work, chances are that the unit is defective.  I have the same problem right now and I'm having to send the unit back to Presonus.  They charge $85 for parts labor and the return shipping.  The replace the entire board, so it's like getting a new unit.  Hope that helps.
Jackie
Oct 17, 2006 | PreSonus FIREPOD (673454000539) Audio...
Vivitar DVR-550 DV Camcorder Logo
14 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
 John
John
J D Wright
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
