Question about Fuji FinePix A500 Digital Camera
Rechargeable Batteries I was given a set of rechargeable batteries with my new Finepix A500 camera which came with a set of non rechargeable double A's. The original batteries are now dead and i wanted to swap to the recahrgeables. According to the packaging and the charger they are fully charged but when i put them into the camera nothing happens i cant turn it on. I have checked in the manual and the batteries i have should be compatible with the camera, has anyone else suffered from this problem or know the answer? I would really use rechargeables if i possibly can. Tha batteries i have are nickel metal hydride, 2350mAh, 1.25v
  • Eric Standifer May 09, 2008
    it did work with rechargables.Now it only works with the 3v power supply.I have tried other batts. One thing .When I got the power supply it only worked with batt.door open.Now only when closed.If I open batt.door while on with pwr.supply.It shuts down.have used discharge feature.didnt seem to discharge batts.Have cleaned contacts.It seems internaly batt.function has some how been disabled.But nothing in menu about enabling.any ideas would be helpful
    Novelist:
  • 198 Answers
This is a triky one. Most cameras will work with rechargeable batteries. If they don't work the most probable cause is this: a normal battery has about 1.5 V nominal charge. Because you use 2 of them you get 3 V nominal charge. Most rechargeable batteries have about 1.21 - 1.25 V like yours. This is given by the technology type used in their construction. However 2 1.25V batteries will result in 2.50 V at nominal charge and some cameras woun't go whell with the 0.5 V difference. You should try other types of rechargeable batteries, maybe some of them will work, but it is recomandable to do that before you buy them, so like I said, it's a triky choice. Try to go to a digital camera shop, they may sell rechargeable batteries more compatible with your camera.
Posted on Mar 14, 2007
Battery exhausted even after charging.
There are two possibilities. First, rechargeable batteries do not last forever. Take out your rechargeable batteries and replace them with non-rechargeable ones for test purposes. If your camera works ok, it may be that the camera's charger circuit has gone bad. Try charging your batteries on an external charger. If they charge, it is your camera's charger, if they do not hold a charge, it is probably time for new rechargeable batteries.
Sep 11, 2013 | Nikon Coolpix 3200 Digital Camera
Ive lost my adaptor to charge my fujifinepix a500 how much will it cost me for another one
Since the A500 uses Alkaline AA or rechargeable AA sized batteries, you can purchase an aftermarket battery charger for between 8-15 dollars at the local electronics houses.
You can also swap over and use AA alkalines without any issue.
Dec 03, 2009 | Fuji FinePix A500 Digital Camera
Battery shows empty with new batteries. Recent development. Put batteries in, take a couple shots, battery is empty. Tried with several pairs of batteries. Contacts OK and tight. Suspect a software...
Take a look in your camera's menus. There should be a place where you can select rechargeable or non-rechargeable batteries. That setting enables or disables the battery charging circuit. If you are using rechargeable batteries, the camera must be set accordingly so that the battery charger will turn on. If you are using
Alkaline batteries such as Duracell or other types of non-rechargeable batteries the charger must be disabled. If you do not set that parameter correctly, you will get the symptoms you describe.
Oct 04, 2009 | Pentax Optio M20 Digital Camera
Rechargeable batterie won't work in my Camera.
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
Apr 30, 2008 | Canon PowerShot S5 IS Digital Camera
Battery life is to short!!!!!
Its the camera, I have the same one and it eats batteries like nothing. I suggest rechargables.
Feb 17, 2008 | Fuji FinePix A700 Digital Camera
Fuji FinePix A345 Digital won't turn on
Have you tried using high-drain batteries? 2800mah rechargeables should do the trick. My A345 had all sorts of problems until I used expensive batteries and now it's been given a new lease of life! my camera wouldn't turn on half the time, when it did it turned off as soon I tried to use it, the shutter would refuse to open, all sorts of weird stuff - I have had no more problems since changing to better batteries (high-density Sony first of all, now I use rechargeable).
Jan 19, 2008 | Fuji FinePix A345 Digital Camera
FujiFilm FinePix A500 screen turns off when trying to take a picture
I had the same problem with a fujifilm finepix... It didn't take pictures with 2 sony batteries, just turned off after pressing the shutter. Then I tried 2 panasonic batteries and it worked fine....
My solution: try panasonic rechargeable.
Oct 24, 2007 | Nikon COOLPIX P4 Digital Camera
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Fuji FinePix A500 Digital Camera Logo
61 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
