Question about Altec Lansing ADA 215 Computer Speakers
No sound coming from Altec ADA215 speakers
I have a Dell computer and just set up Altec ADA215 speakers.
The green light is on the speaker, but no sound.
Can anyone help?
  • 2 more comments
  • rayan974 Dec 30, 2008
    I have format mu system and loose the driver.
  • Anonymous Jan 03, 2009
    same ****
  • divinecc Mar 22, 2009
    Same problem, can't seem to find a driver anywhere. Anyone help?
  • Anonymous Apr 11, 2009
    yea like everyone else is saying all you need is just the right driver..."ada215" but i cant find it anywhere...but a driver is all you need.
Http://list.driverguide.com/list/company64/
Posted on Feb 11, 2009
Were in providence can i find a cord to my altec lansing model:ADA215 speakers
https://www.google.com/search?q=altec+lansing+model%3AADA215+speaker+cables+&ie=utf-8&oe=utf-8&aq=t&rls=com.yahoo:en-US:official&client=firefox&channel=sb
Oct 02, 2014 | Audio Players & Recorders
Hello I have a set of Altec Lansing ADA215 speakers, and one of my speaker has very low sound level. This was not before I dont now what happend I hope you guys have an idea. Thanks B.Versloot
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Apr 10, 2011 | Altec Lansing ADA 215 Computer Speakers
Makes a loud noise when i turn on and no sound plays. I don't think i need drivers but either way they're impossible to find. I have Altec Lansing ADA215 Computer Speakers.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 31, 2010 | Altec Lansing ADA 215 Computer Speakers
Installation of speakers
The speakers require the AC adapter to be connected for the speakers to function. The AC adapter powers the amplifier of the speakers
http://support.dell.com/support/edocs/acc/ada215/ada215.pdf
Apr 18, 2010 | Dell A215 Computer Speakers
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
No sound will come out please help
Speaker Manual Dell A215
Ensure speaker port is working fine by connecting headphones.
Use Volume Knob to turn on the speaker
Jan 14, 2010 | Dell A215 Computer Speakers
NO Sound from NEW speaker unit?
Yes the green wire that goes from the speaker should be plugged into the green jack on the PC. An easy test to see if its the computer or the speakers is to have the speakers on and volume up a little and tap the tip of the green plug with your fingers while out of the computer. If it makes a humming or any noise at all while tapping, the speakers are working if not lets check voltage at the power plug or if the unit has any lights on. Gook luck!
Mar 25, 2009 | Altec Lansing Multimedia Computer Speakers
Altec Lansing ADA 215 Computer Speakers Logo
1,474 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
