In Corel Paint Shop Pro X I'll take a great deal of time with an enlarged image deleting extraneous pixels one at a time and end up with a sharp image -- when I return to the image at a later date, I find that all the extraneous pixels are back and the image is softened and no longer as sharp as I had created - I'm not sure which of the following settings might affect the image but they're all set at 100: Hardness, Density, Thickness, and Opacity -- thanks for your help -- Mason Lewis
  • 7 more comments
  • masonclewis Dec 14, 2008
    I'll take a great deal of time with an enlarged image deleting extraneous pixels one at a time and end up with a sharp image , which I save and close Paint Shop Pro X -- when I return to the image at a later date, I find that all the extraneous pixels are back and the image is softened and no longer as sharp as I had created - I'm not sure which of the following settings might affect the image but they're all set at 100: Hardness, Density, Thickness, and Opacity -- thanks for your help -- Mason Lewis
  • masonclewis Dec 23, 2008
    I'll take a great deal of time with an enlarged image deleting extraneous pixels one at a time and end up with a sharp image , which I save in a bmp format and close Paint Shop Pro X -- when I return to the image at a later date, I find that all the extraneous pixels are back and the image is softened and no longer as sharp as I had created - I'm not sure which of the following settings might affect the image but they're all set at 100: Hardness, Density, Thickness, and Opacity -- thanks for your help -- Mason Lewis
  • masonclewis Dec 30, 2008
    I'll take a great deal of time with an enlarged image deleting extraneous pixels one at a time and end up with a sharp image, which I save in a bmp format and close Paint Shop Pro X -- when I return to the image at a later date, I find that all the extraneous pixels are back and the image is softened and no longer as sharp as I had created - I'm not sure which of the following settings might affect the image but they're all set at 100: Hardness, Density, Thickness, and Opacity -- thanks for your help -- Mason Lewis (I'm not getting any response on this)
  • masonclewis Jan 05, 2009
    Ohms reply to my problem: "on what format is the image saved?" -- I stated in the posts of December 23 and 30 that the images were saved in the bmp format -- if that is not the information he needs, he'll have to clarify
  • masonclewis Jan 13, 2009
    posted by masonclewis on Dec 14, 2008
    Comment posted on Dec 14, 2008
    Comment posted on Dec 23, 2008
    Comment posted on Dec 30, 2008
    Comment posted on Jan 05, 2009
  • masonclewis Jan 22, 2009
    Ohms reply to my problem: "on what format is the image saved?" -- I stated in the posts of December 23 and 30 that the images were saved in the bmp format -- if that is not the information he needs, he'll have to clarify -- also, I am not talking about the edges of images which, if magnified, will show the jagged pixels - I am referring to just beyond the edges on the white or other color background, or even in the image itself where I had saved it in one color and come back to find that area no longer solid one color, but rather, filled with phantom pixels (practically the same color but different enough to "soften" the image -- a response to my email would be appreciated since the responses on your site seem to get lost (masonclewis@aol.com)
  • masonclewis Feb 03, 2009
    Still no solution -- how about a refund?
  • masonclewis Feb 22, 2009
    Please schedule a credit to my account -- thank you
  • 19,396 Answers
Your mistake is saving the image.
Just use export command and export the image on JPG format , and chose the folder where to save onto your PC.
Do not work on Corel straight on camera memory card.
Posted on Jan 14, 2009
    Genius:
  • 1,011 Answers
Sir,
Click this link for more info.
thanks
good luck
Don't forget to rate the solution
Posted on Jan 13, 2009
    Scholar:
  • 143 Answers
U need to reset all image again there no oter way to get back u need to set setting then re save it as per my thot u have to reset again
    Genius:
  • 1,269 Answers
Please redo your changes and please save the file with a different filename and different location. You need to specify the BMP pixels as well when you save it.
Posted on Dec 30, 2008
    Novelist:
  • 59 Answers
Hi Mason -
100 is the default setting for each of the parameters you've listed. If you change them, save the file, and close and reopen it later, they'll all be set at 100 again (corresponding to your most recent saved settings).
If you edit the pixels by placing new color over the pixels in question, then it's possible that your adjustments are still there; they've merely been hidden behind the original image. Try selecting the original image and clicking Edit > Arrange > Send to Back. That way any individual pixels you've added in a different layer will show up in front of the original image.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 14, 2008
    Sergeant:
  • 306 Answers
Check whether in any case of settings the default value given as 100 or not. if it s given then u need to erase those default values. only then the image remains with the constant changes in settings..
  • 734 Answers
The jagged edge ("aliased") factor is because the images created in CorelDraw are vector based, expressed mathematically on the screen and will always look sharp and crisp if you zoom to it's limit, and they're being exported to a bitmap format which is expressed in pixels which look more jagged the more you zoom in or more you enlarge them.
 To minimize this effect, make sure that the images are the exact size that you're going to use them at: if the image on your website is for example intended to be 3" x 2", make sure the image in Draw is that exact size, and export the image at 100% @ 72 DPI resolution and don't try to resize them on the web page. There's no need to import into Paint unless you want to change the color or otherwise edit the art once it's been exported to a bitmap.
Good luck,
Thanks
    President:
  • 1,952 Answers
TRY THIS LINK www.techsupportforum.com/design-forum/graphic-design-digital-imaging.../87527-problem-paint-shop-pro-x.html - 49k
  • mohammed marika thambi
    mohammed marika thambi Dec 14, 2008
    op Pro ...
    #mid_col .grad { width: 300px; overflow: hidden; }
    #mid_col .grad_content { width: 280px; overflow: hidden; }
    Color Correction in Paint Shop Pro 9 or X
    By JustMeof3, published Aug 10, 2007
    Published Content: 112 Total Views: 169,027 Favorited By: 33 CPs
    Contact
    Subscribe
    Add to Favorites
    Embed:
    Rating: 4.0 of 5
    Font
    Font
    Grab this
    close window
    Taking
    a perfect picture every time is impossible, and inevitably some
    pictures are going to come out wrong, such as having a color cast from
    an incorrect white balance. But you don't have to set those images
    aside as unusable. Using Paint Shop Pro, you can remove a color cast
    easily and preserve the picture the way it was meant to look. This is
    also useful for restoring photos which have become yellowed with age to
    their original colors.
    Open Paint Shop Pro, then open any image
    (that you own, have permission to use, or is in the public domain) that
    has a color cast you want to remove. You may want to save a copy of the
    image and then close the original to avoid saving inadvertent changes
    to the first image.
    The quick and easy fix for a color cast photo
    is to use Automatic Color Balance. Click on Adjust, and then click on
    Automatic Color Balance. In this menu you will find different options
    for correcting the color in your image. Place a check in the Remove
    color cast box, and adjust the Strength to achieve your desired result.
    Notice the Illuminant temperature at the bottom of the menu, and move
    the slider left or right depending on the lighting conditions when the
    picture was taken. If you don't remember, just make adjustments toward
    warmer or cooler until you are satisfied with the resulting image in
    the preview and then click OK.
    You can leave the altered picture
    as is and save it, or use the Manual Color Correction option to adjust
    the color balance further. Click on Adjust, go to Color Balance, and
    then click on Manual Color Correction. In this menu you can choose
    Preset target color and then select options such as hair colors, skin
    tones, grasses, or metals. Alternately, you can choose Manual target
    color and then adjust the Hue, Saturation, and Lightness to your
    satisfaction. When you are finished, click OK.
    Save your corrected image with a different name from the original if you did not save a copy at the beginning, and you're done.
    mohammed marika thambi Feb 04, 2009
    contact fixya
  • 1,879 Answers
On what format is the image saved?
  • 13,433 Answers
It maybe the format you save the picture in, try to save the picture as a bmp that way all the pixels will always be the same and they wont get changed in compression, since there is none.
So give .BMP a shot
    Master:
  • 479 Answers
You will have to save the changes what you make if u will not save it will not become as u wanted.
I have problems with pure hd...
Hi Taba,
Please use the below link to download the original version of the Corel Paint shop Pro X version for PC's
http://www.softpedia.com/progDownload/Paint-Shop-Pro-Download-5709.html
Once you opened the link,click on Externl Mirror 1
Save the file and install it.
Please check and revert back to us is yo have any other issues
Thanks for contacting Fixya
Regards,
Aysaam
Feb 27, 2011 | Corel Paint Shop Pro® X Full Version for...
How to uninstall PureHD.msi
I tried everything over 6 months.
Finaly used REGEDIT.
Searched for any PURHD .
Found plenty , tied to corel pro3.
Deleted ALL enties manualy, no damage.
Fixed at last!!
Mar 03, 2010 | Corel Paint Shop Pro® X Full Version for...
Paint shop pro x2 ultimate upgrade wont rum on Vista Home
I havent actually solved the problem but I did get PaingShopProUltimate to run by starting up in "SAFE MODE" I tried it out and everything seemed to work ok. but of course this is not very convenient.
Sep 05, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
My psp freezes on *updating cache setting*
I found this fix that worked for me:
A. Close Paint Shop Pro Photo XI if is currently open.
B. Go to Start | Run, Type %appdata% and click Ok. (Or find the folder under user\appdata)
C. Open the Corel folder.
D. Delete the following files:
ImageDB.db
LastDBFilter.PspCache
LastDBTreeSel.PspCache
thumbnails.db
E. Select the Paint Shop Pro Photo folder.
F. Select the 11 folder.
G. Delete the cache folder.
H. Close the open box.
Aug 18, 2009 | Corel Paint Shop Pro Photo X2
Corel Paint Shop Pro X will not respond or open
Please inform corel from the internet and tell them that you purchased the 2007 version of paint shop Pro. tell them that you needed to install back unaccessed software.
Thanks.
Jul 09, 2009 | Corel Paint Shop Pro® X Full Version for...
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
COREL Paint Shop Pro PHOTO XI
where can i download corel paint shop pro 2 user guide?
Jun 11, 2008 | Corel Paint Shop Pro Photo X2
Text is blurred
The problem is with text font size and image resolution. These two are married together. In other words one supports or hinders what the look of the end result will be. Increase the pixel depth of the image and then insert your text with a larger font size and the result should be clearer. As you may know, when you enter text it becomes another layer in your image. Once the object in this layer is created it can be resized. And, resizing may be the answer to get the font size you actually want and a crisp, no pixelated, edge for your type face.
Can you exchange messages with me over the next 12-24 hours as I give you a tutorial with your current project?
I have a business to run myself and just so happens that today and tomorrow I'm pretty busy. But, I've taught this software in version 7 at our community college a few years ago and help local clients all the time with PSP.
Regards,
Worldvet
May 21, 2008 | Corel Paint Shop Pro 9
Computers & Internet Logo
David Payne
David Payne
