Question about Clark 's Bicycle Brake Shoes Rim Pad Hydraulic Magura, CP310
Seals perished on hydrolic magura race line brakes ?
Is it possible to replace and if so where can i get them?
  • 73 Answers
Got that one in one , i use a website in northern ireland called Chainreactioncycles and they carry Magura brakes complete and parts, i know its an online shop but i buy everything from them and the bargains are fantastic and shipping minimal
Posted on Mar 27, 2010
Is vitamol v10 the same spec as magura blue blood
All the above answers saying to use a DOT or other fluids are wrong.
Never use DOT-3 or DOT-4 based fluid in a system equipped for Magura's Blue Blood or Vitamol V10 mineral oil. Using DOT-3/DOT-4 fluids will likely cause seals to fail in your clutch or brake cylinders.
To answer your question: yes, I believe both Blue Blood and Vitamol V10 products are equivalent SAE10 weight mineral oil.
Jan 05, 2013 | Cars & Trucks
How do i change front wheel bearings
Instructions
    • 1
      Jack up the car. Use jack stands if possible, or blocks if not.
    • 2
      Remove tires on the front. Remove brakes.
      • 3
        Take out the grease cap (the center).
      • 4
        Pull out Cotter Pin. Take nut out.
      • 5
        Pull Rotor out. Take grease seal off of the back of the rotor. Pull out inner and outer bearings.
      • 6
        Using hammer and punch, knock out racings from the back of the center of the rotor (very important to use new races, don't use the old ones). Clean out the center of the rotor with a clean rag.
      • 7
        Using the new bearings, replace the old ones, tapping them into place. It doesn't matter which one you install first.
      • 8
        Pack with grease when they are in place. Install new seal after the bearings are packed with grease.
      • 9
        Re-install the rotors into car; put brakes back on; replace tires; You're ready to go!
    Read More: Chinasinoy
    Aug 02, 2012 | 1998 Isuzu Trooper
    I need to know the name of brake parts for a 1988 Ford Ranger. It's for the front brakes. Does anyone have a manual?
    rotors,pads,calipers,brake hoses,brake lines,front brake hardware,wheel bearings and the races,grease seals i hope this helps you. richard
    Apr 11, 2010 | 1988 Ford Ranger
    2004 passat 4motion wagon is it a clutch cable or hydrolic? we do not have the owner manual The car starts but you can not put it into gear. It feels like the hydrolics are gone. I can not find where the...
    It is hydraulic and uses the brake fluid.Follow the line to the gearbox from brake fluid bottle to just under oil filter and there is a small cylinder that can break its seals and stop the clutch working and its easy to replace
    Dec 26, 2009 | 2004 Volkswagen Passat
    Brakes are squshy
    Have you had any work done on the brakes recently? 1st make sure the fluid level is ok. This can be either air in the lines (that's why I asked if any work was done on the brakes recently), or your master cylinder may need to be replaced. So, make sure there is no air in the system before spending $ on a master cylinder.
    Nov 22, 2009 | 1998 Plymouth Grand Voyager
    How do you bleed a Magura Marta hydrolic disc brakes
    There is a basic walkthrough for most hydraulic brakes here. http://www.parktool.com/repair/readhowto.asp?id=126. Keep in mind that each manufacturers brake system has specific techniques and tools. Search the website for the brake model and manufacturer that you have.
    Jun 05, 2009 | Cycling
    Brake hydrolic pressure loss.
    you still have air in the system,you need to cross bleed the system,RR,LF,LR,RF.if this does not work you might try picking up a hand operated vacum pump to help get all the air out.
    Apr 29, 2009 | Toyota Land Cruiser Cars & Trucks
    Replacing brakes and resurfacing rotors
    Front rotors on a 2 wheel drive means you have to take out bearings and all, it is recomended that you replace the bearings and races because they will have to be removed to turn the rotors might add 30 bucks to the total , you should check around because some rotors are cheap enough to replace instead of turning them. You can re-use the bearings as long as you are careful not to damage the races
    Remove the brakes, caliper and caliper braket, remove center dust cap, remove cotterkey and spindel nut, pull rotor off you might need to give it a whack with a deadblow hammer to get it off of the seal in the back, front bearing should fall out in your hand ,with the rotor off gently pry the rear grease seal out (have a new one on hand they damage easy) remove rear bearing. Clean all the grease out of the rotor center so you can see what you are doing, once cleaned with the front of the rotor on the table you should see some notches at the bottom race,this is where you will place your punch to remove the race, flip the rotor over and do the same to remove the other race. Borrow or rent the proper tool to put the races back in, they have to go in straight and you will probably damage the races putting them back in with a punch. When you put it all back together remember to re grease everything. Do not over tighten the spindle nut when putting the rotor back on,tighten it enough to take out any play then tighten it just enough to line up the holes for the cotterkey. Then take it to a mechanic and get the bearing runout checked and set.then put your brakes back on
    Mar 23, 2009 | 1991 Ford F250
    Brakes
    Flexible brake lines are probably balooning out causing pressure not to build up, replace flexible to the calipers.
    Jul 26, 2008 | 1989 Chevrolet Silverado 2500
    Clark 's Bicycle Brake Shoes Rim Pad Hydraulic Magura, CP310 Logo
    171 people viewed this question
    Top Clark Cycling Experts
    Michial Gueffroy
    Andrew Taylor
    Andrew Taylor
    Are you a Clark Cycling Expert? Answer questions, earn points and help others
