Question about Car Audio & Video
How to set the time on the oem 1987 dodge radio?
No clue how to set the time
Turn radio on push set button within 3 seconds push volume button use tuner button to turn hour up or down then push volume once more to change to minutes then use tuner to set minutes then turn radio off then back on clock should now be set
Posted on Mar 13, 2013
Is there a button or tiny hole to set the time
Posted on Dec 13, 2008
When i try to play a cd it tells me to reset the cd how is this done
is your cd player aftermarket or oem if oem look in owners manuel u will have to do a soft reset on the radio if not disconect positive battery terminal and hit the power button a few times wait 2 min and replace cable.
Mar 27, 2012 | Aiwa Car Audio & Video
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
I have a 2000 chevy C2500 with a OEM Delco radio/cassette, how do I change the time?
Turn ignition or accessory on with the key. Turn the radio off. Pull the scan button to set hours. Pull the seek button to set minutes.
try that.
Mar 26, 2010 | Car Audio & Video
1993 ford tempo OEM radio removal. I have the U
I do not know where you live but wher i am are a chain of outlet stores called princess auto and they sell a small blue box of radio removal tools which work on almost every car on the market it is only around 10 bucks for the set and I would think you could purchase same at some auto parts stores if in US the chain icannot reember similar to PA is Harbor something or other cannot remember but it sells almost same stuff you can try one of them I will ask my friend the name he goes there whenever he goes south You can contact me at sully1950@live.ca and I will get you the name ...good luck in the meantime
Dec 26, 2009 | Car Audio & Video
How do install a 1998 toyota camry radio into a 1990 car?
Just use the install guide with the property plug connections:
- Uninstall Toyota Camry 1999-2000
- Install Toyota Camry 1987-1991
For reference to Toyota radio wire harnesses, review this wiring diagram for 1987 and Newer
Hope helped with this. Good luck.
Nov 09, 2009 | Car Audio & Video
Setting the time
PRESS THE 'SEL" BUTTON MORE THAN TWO SECONDS AND THEN WITH THE KNOB VOLUME CHANGE SET HOUR THEN PRESS THE FORWARD BUTTON TO SET THE MINUTES WITH THE KNOB VOLUME THEN PRESS SOURCE.
Mar 18, 2009 | JVC KD-G140 Car CD Player
Setting clock on stock radio/CD/casette player in 1999 Dodge Ram
push and hold the clock button until the hrs flashes then use tuning button to change numbers or if your radio had 2 small pen tip buttons that read hrs & min pushing these with a pen tip will set the clock
Dec 03, 2008 | Car Audio & Video
Security code not working
y this
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Jan 10, 2008 | Kenwood EZ500 CD/MP3/WMA Receiver
Car Audio & Video Logo
313 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
