Question about Samsung SyncMaster 193V 19" Flat Panel LCD Monitor
Samsung SyncMaster 193V magicbright
Recently started having problems with monitor a box appears in bottom left corner called magibright which relates to a button on the monitor , it`s as if the button is stuck in , but it isn`t it scrolls between 4 different brightness settings repeatedly, carn`t fix it? any one got any idears , be apreciated cheers mark
Hold the menu button down until the menu disapears again
Posted on Sep 07, 2008
SOURCE:
How do I delete list of "New Calls"
If you've got an iPhone, you probably already know that it can provide you with a history of your calls. You can also edit your call history if and when you need to by deleting individual call records. Whatever the reason (hey, we don't judge), we can walk you through how to delete certain phone records out of your call history.
  1. Launch the Phone app from the Home screen of your iPhone.
  2. Tap on the Recents tab along the bottom of the screen.
  3. Now tap on the Edit option in the upper right hand corner.
  4. You'll now see that each phone record now has a delete option to the left of the caller's name or number. Tap on it.
  5. To confirm the delete, tap on the Delete button off to the right.
  6. Repeat this process for the calls you'd like to remove and once you're done, tap on the Done option in the upper right hand corner of the screen.
That's it, those calls will now not appear in your recent calls any longer.
How to delete individual call records from Recent Calls on your iPhone
Nov 15, 2016 | Cell Phones
I can't figure out how to change from right hand click to left hand. Please tell me how to do it. thanks
start run control panel mouse/ buttons/ configuration
press ok............
cheers
Mar 27, 2011 | Computers & Internet
Gj912DW110 HSD190MGW1A appears in top left hand corner of screen . How do I get rid of them ?
Hi there
This is probably a runtime error,what you should do is to;
Open Internet Explorer on your desktop. Click on "Tools" in the upper menu and then "Internet Options."
Select "Advanced" and look at the box showing multiple options that can be activated with a green check mark by clicking a little white box to the left.
Scroll down until you see the message "Disable Script Debugging"--one for Internet Explorer and the next for "Other" underneath. Both "Internet Explorer" and "Other" are in parentheses.
Click into the white boxes to the left of each one so the green check mark appears.
Press "OK" at the bottom, and the runtime error messages shouldn't ever appear again when you use Internet Explorer.
Sep 16, 2010 | Gateway FPD1975W 19" LCD Monitor
I need help to install this program
Hello Cryspycritte, Thank you for the clarification. Your program is definitely compatible with Windows XP. What you will need to do is put Disc 1 of Print Workshop into your CD drive. Click on your start button in the lower left hand corner of your desktop, then click run (located right above the "turn off computer" button.) A run box will appear in the bottom left hand corner. In the box type: D:\setup.exe (where D is the letter of your cdrom.) A setup window will appear with the final steps for installation. If you have any installation issues please post a reply. Thanks for using FixYa! Edward
Aug 24, 2010 | ValuSoft Print Workshop 2003 for PC
What is the best setting on adell 24
The issue is relative to the native resolution of the monitor. in most 24" monitors the resolution is 1920 x 1200. When you get an application that is shown in the upper left corner of the screen, it is most likely set in a page frame of 800 x 600 or 1024 x 768. Also many web pages will display with large amounts of white space on one or both sides.
This you can do to help.
Set the DPI setting in display properties to 120 will help some making small type more readable.
Pages that are in Internet Explorer can be zoomed to appear larger zoom feature in bottom right corner of IE window (or CTRL & + and CTRL & - key combinations)
Oct 03, 2009 | Computers & Internet
Samsung 731N Auto Adjustment
I'm having the same problem. Started three days ago. Really annoying. First I downloaded a driver because that was reccommended over plug and play. But that did not fix the problem. I ended up pressing the menu key (1st on left) and while holding it down I wedged a little piece of paper to hold the key down and the popup menu's have stopped. The box can be the brightness/contrast or auto/image reset/color reset ...
it doesn't matter, they all popup after pressing buttons left and right. Have no answer to correct the problem but at least I can now compute without these stupid menus.
Dec 27, 2007 | Computers & Internet
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
How to use buttons on front of Monitor for vertical Horizontal settings
Oldie, The first thing to do is set the monitor resolution, color depth and monitor refresh rate to what you want then adjust the monitor accordingly. Adjust resolution, color depth and refresh rate for Windows 2000/XP: -Right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) experiment with the resolutions and see what you like. -The color quality box should be set to the highest (most colors) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -Typically you would want to set it at 70 Hertz or better. The higher the setting the less flicker you will notice, however, there is always a trade off. I would start with 70 Hertz and gradually move up; at some point your monitor will reach a setting it can?t support. If the screen blanks out Windows will reset back to the previous settings as long as you don?t hit any keys. -click the OK button twice. More to follow?.
Mar 14, 2007 | ViewSonic E790 Monitor
Monitor problem
Melanie, The computers video cards resolution and / or refresh rate is set incorrectly for your monitor. The easiest way to fix this is as follows for Windows 2000 or XP: -While the computer is first starting press the F8 key every second till the Advanced Options Menu appears. -Using the up or down arrow key select the ?Enable VGA Mode? and hit the enter key. -You will be taken to another screen that may or may not have several items to select from. Find your operating system, highlight it and hit the enter key. -Your computer should now load Windows using a generic display mode. Don?t be alarmed if the objects on the screen appear large, this is just temporary. -Log into Windows (if necessary) and you should now see your desktop. -Ignore the popup in the lower right hand part of your screen saying that the display is set very low. Simply right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) make sure it is set to 1280 x 1024. This is the typical resolution for a 17? LCD but be aware that your monitor will probably be capable of supporting other resolutions. -The color quality box should be set to the highest (most) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -The typical LCD is set to 60 Hertz; however, I have seen where some Acer monitors like 70 Hertz. I would start with 60 for now and change it to 70 if this doesn?t work. -click the OK button twice. -Restart your computer normally and see if it works. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 09, 2007 | Acer AL1716B 17" LCD Monitor
Samsung SyncMaster 193V 19" Flat Panel LCD Monitor Logo
1,122 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
