Question about Danby DMW1153 Microwave Oven
Is my dented microwave safe to use?
Hello - we recently had a small mishap in our kitchen, and our microwave received a small dent in its outer casing. I have always heard that you shouldn't use a dented microwave, but since there is no damage to the inside compartment of the microwave, I am not sure whether it is safe or not. The dented area is on the side closest to the clock and button panel, not the side closest to the interior of the microwave. The bottom edge of the outer casing has slightly popped loose. The microwave is four or five years old; it is a GE Turntable, model JES1039WF 001. Thanks so much for your help!
  • 706 Answers
Hello carillon553,
If you haven't compromised the door opening or inner compartment, then it is more than likely OK to use. The magnetron ( which generated the microwave energy ) has a waveguide that focuses that energu into the cooking compartment and a small dent to the cabinet normally has no impact on its safety.. Hope that helps..
If you are overly concerned with that, then you would need a technician that has an RF Power Meter to check it.. If it were me, and the dent was small.. I would just use it...
Regards,
Rick
Posted on Dec 13, 2008
Change bulb in microwave
Most microwave ovens require the outer casing to be completely removed in order to get access to the bulb. This is not always easy and may require special tools etc.
Apr 20, 2016 | Neff Microwave Ovens
Dent inside the microwave oven
if its just you and her, use it. if you have kids, replace. could cause a fire in a worst case senerio.
Jun 19, 2012 | GE Microwave Ovens
I have a small dent in my stainless steel refrigerator. I've tried a plunger and the blow dryer and dry ice trick any other ideas?
Because it is stainless steel it is not likely that it will come out the compressed air and blow dryer are you best bet but it is unlikely that it will come out
Mar 05, 2011 | Microwave Ovens
Turn table not rotating
Hello there:
This is a very common problem on these microwave's the turntable is driven by a small gear /motor that sits directly beneath the plate so what is needed to be done is to remove the outer case by first removing all of the outer screws on the back and along the outside edges of the cover then the cover will slide back about 1 inch and lift off then you will be able to see the motor i am talking about it will look llike the one i have a picture posted below simply unplug the wire and the part will come out fairly easy then replace the part and plug in the wire to it and then plug in the microwave and test if works then just put the outer cover back on ok?
should look something like one of these below
Feb 01, 2011 | GE Microwave Ovens
Is there a fuse on a Microwave. 14 yrs old just stopped working. Can it be fixed or should I just buy a new one.
Hello there>
Yes there is a fuse inside of the case but you have to remove the outer shell first by removing the screws around the outer back then the side screws then the case should slide back and lift off
Then look at the front on the right side and you will see what looks like a small electronic board the fuse will be on there it simply pulls out of the holder and then the new one goes in there looks like this one i have posted below Now if this dosent work you have a problem with the power inverter or the megatron
Jan 21, 2011 | Sharp R-3A88 Microwave Oven
I have a DCS Model MO-24SS. The other day I was
Main fuse is under outer cover Its a large ceramic fuse and costs about $30
Jul 25, 2009 | DCS MO-24-SS Microwave Oven
Can a novice do this...how do I do it, step by step?
Disconnect from electricity. Remove screws holding outer casing and you will see the inline fuse. Make sure there is nothing that will cause the fuse to blow again. Always replace the outer cover before testing.
May 20, 2009 | GE JVM1630 Microwave Oven
DENT MICROWAVE
As long as the door seal is not bent or broken it is safe to use!
Please rate this free response!
THANK YOU!
Jan 17, 2009 | Danby DMW1153 Microwave Oven
REMOVE WALL MOUNT MICROWAVE
TO: capt_bob1954:
You can find an exploded view of the outer case & installation parts for the 564.8775380 model here. Maybe that will help.
If not, on that same page, it shows where you can order a copy of the installation instruction manual for $4.99. It's probably worth it to save a lot of aggravation.
We're happy to help and we appreciate your thoughtful rating of our answer.
TO: Guest
You can find an exploded view of the outer case & installation parts for the 665.68601891 model here. Maybe that will help.
If not, on that same page, it shows where you can order a copy of the installation instruction manual for $9.99. It's probably worth it to save a lot of aggravation.
Feb 19, 2008 | Microwave Ovens
Danby DMW1153 Microwave Oven Logo
2,387 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
