Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 - water leak not from hoses - could it be the pump?
Hi - top loading Kenmore 80 - leaking water DURING the cycle. Looked under the machine and no visible leak from the hoses although the pump (think that's it) has water leaking from it. What is a good way to troubleshoot or get the cover off to troubleshoot? If its the pump, is this best to outsource.
Thanks in advanced to those who can help.
- Glenn
  • frsigman Dec 13, 2008
    Thanks Ken... It's model number is 110 26832690 Kenmore 80.
  • maura_flynn Jan 11, 2009
    Much easier to access the pump by removing the cabinet in its entirety, which is also much easier than trying to remove the back panel. For instructions, see http://www.applianceaid.com/procedures.h...
    You can examine the pump easily on the front of the washer, below the tub. I have exactly the same problem - no leak from the two hoses attached to the pump. Water is coming out of the seam where the two pieces of the pump were fused together during manufacture. The url above also gives directions for replacing the pump.
    Problem Solver:
  • 14 Answers
Hi Gleen you probably need to remove the rear cover to expose the in side of machine.
Note if you could post a model number I could tell you for sure what would be the best way get to the pump.
Posted on Dec 13, 2008
  • ken67 Dec 14, 2008
    Hi Gleen I looked at the diagram on this model and you should be able to access the pump by removing the rear cover.
    this should be a easy change the water pump is located on the rear of the electric motor held on by two metal clips pop these loos with a screw driver remove hoses with pliers the pump should come off at this point replace in opposite order so if you have any mechanical ability at all you should be able to do this job. Note be sure to disconnect the power and have a couple of towels handy will be some water when disconnecting the pump.
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
Ge top load washer leaks from over flow during spin cycle
check your pump it may be partly plugged if it is try to clear or replace pump
Aug 06, 2009 | Washing Machines
I have a top loader kenmore elite washer that is leaking. The service guys have replaced everything from valves, tub ring and the fabric softner dispenser but its still leaking Help
Hi, Did they check the pump seal or the hoses. Does it seem to leak from the front center? Is it leaking while filling or during agitation or spin cycle? Are you getting water every load and is it a little water or a lot?
Please forgive all the questions, I have to ask.
Questions I need to ask in order to assist you as best I can.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 series. Leaking from front under washer. Can hear standing water under agitator/basin
Usually with this situation its a pump leaking, does it leak mostly during use.if you lean appliance back, should be able to take a peak underneath at pump. will just need to be replaced if leaking.
Jun 08, 2009 | Kenmore 22422 Top Load Washer
Washing Machine stops and leaks
A Clothes Washer with the complaint "Leaks in Front" (on floor) can be;
Defective Water-Pump (Very common of non-belt models) - Many water-pumps become defective due to the constant wear and misc. items becoming lodged (coins, necklaces, shoe laces, screws, etc.) or breaking the plastic housing or connections. The water pump is fairly simply to replace and is located on the inside front of the machine.
The water pump is typically a white or off white plastic and will have (2) black drain hoses connected; one coming from the tub and the other going to the drain out the back/rear of the machine. Electric pumps with typically of 2 wires going to and connected to the pump. ** Note: When disconnecting and removing the water-pump, becareful of water remaining in tub that may come shooting/flowing out.
-C
Fremont, CA
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite, water leak
Check the mix valve area where the water enters the machine, during the fill.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 seeping water from under machine
look underneath the washer.there sould be a hose there.sometimes an unbalanced load can cause the hose to rub up against sharp metal when the machine vibrates.mine had a zip tie that held the hose to close to the edge of the machine which had some sharp metal and it put a small hole in the hose.hope this helps.
Dec 19, 2008 | Kenmore 22422 Top Load Washer
Leaks
to jim, you may want to check the water pump closer, sometimes the water pump will leak a little during a cycle and the water will leak somewhere on the floor, not necessarily near the water pump.
to the second post (guest), it sounds like you have a bad water valve. the valve is not closing properly and causing water to leak thru.
Jun 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
89 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
