FixYa.com
Tags:
Epson Stylus CX6400 All-In-One InkJet Printer
Problem with print outs from printer
posted by eastman on Mar 11, 2007
I have a CX6400 Epson printer. I am getting gaps in my print outs when I do a test to see where the gaps are, they are in the cyan. I have cleaned the print heads several times and the gap is still there. Is there a way to do a more thorough cleaning on just the Cyan head? Thanks
Eastman
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 12, 2007
FixYa! (100)
Inky
Rank:Guru Guru
Rating: 85%, 612 votes
Hey eastman
You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag.
The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead.
With the top of the machine open, you should be able to move the print head carriage by hand.
Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink.
Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image)
Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked.
Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something.
What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick.
Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers.
Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times.
Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel.
Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines.
This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
Comment by Inky, posted on Mar 12, 2007
IMAGE 1
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 19, 2008
Not Rated (0)
trimmir
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My CX3200 was not printing anything. Read over the advice offered on this site.Tried head cleaning, noted ink was running, because of the subsequent ink collecting below the park station.
Figured heads must be clogged.
Ordered cleaning solvent online. Once it arrived I used isoproply alcohol to clean excessive ink around park station. Used the purchased solvent with Inky's method of underhead cleaning, also injected solvent through the wicks.
Did the trick. All four heads print.
Thanks,
Trimmir
Can you Help with these Printers problems?
Ink Cartridge
The cyan ink wont print, it is... Answer This...
Scanner problem
I have an Epson Stylus CX6400... Answer This...
10000xl won't power up
I am unable to turn my scanner... Answer This...
Epson Stylus CX6400
I was given this printer with... Answer This...
CX6400 Power supply
Printer has worked great for 2... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
