RCA Model P61950
Where is that fuse fl231
  • 1,030 Answers
The fuse fl231 is not in the p611950 its in the rca chasis itc222 next to the flyback
Posted on Dec 14, 2008
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
Where is the convergence fuse located on a RCA M# R52WH76
Right to the right side of the flyback. You will see three small brown rectangle ( fuses) FL221, FL231 and FL251 the center fuse is the FL231 which is the fuse for convergence. I am posting a pic of where its located.slinteriors_14.jpg
Jul 20, 2011 | RCA R52WH76 Television
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
Double picture, red,blue,green lines
consult the Article in the tips and tricks section "the fl231 problem" give complete instructions on this simple repair and where to locate the fuse
May 10, 2009 | RCA R52WH73 Projection Television
FL231 Fuse Location
the fl231 fuse is a small rectangular fuse tan or brown in color. located on the deflection board next too what is known as a flyback transformer. this is a large black componet with two wires coming from the top. one large red one. it looks sort of like a dristibitor of a car ... too the right there is three small rectagular parts these are fuses the one in the middle is the fuse
Apr 04, 2009 | RCA HD52W59 HDTV Projection Television
I need to replace FL231 fuse.
Yes you must take back off and NO do not lay set over! POwer/deflection board is first board on bottom to left on right side bottom SSB board. FL231 is located on right side of FBT it has 2 wires coming out from it red/black(3) fuses look like small brown caps right in a roll it will be the middle fuse
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
Images doubled and red blue green colors all seperate
Look in menu go to setup see if you have convergence listed on menu if not you have open fuse FL231, located next to flyback on right side there is 3 in aroll small brown looking caps middle one is it FL231.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
RCA HDTV Fuse location
There are 3 small rectangles that are on the right side of the flyback, they are micro fuses FL231 is the center one. I am not sure if radio shack has them, may have to order from RCA
Jun 30, 2008 | RCA R52WM24 52" HDTV Projection Television
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
