Question about Sony Handycam DCR-HC30 Mini DV Digital Camcorder
LCD touch screen malfunctioned
I could not watch the movie because the touch screen doesnt work to play back the tape and making adjustment.
Thanks.
Robel
  • 1 more comment
  • robel_ison63 Dec 13, 2008
    tHANKS FOR YOUR HELP, I TRY TO REPLACE THE RIBBON WIRE AND WILL LET YOU KNOW LATER.
    ROBEL
  • elena85 Jan 04, 2009
    Hi. My Sony Handycam DCR_HC30 touch screen is not working. I cannot sent the date, rewind my tape, nothing. Please help. Thanks
  • esam abdul wali Jan 07, 2009
    LCD touch screen is not working , i tray to make calibration but still same problem aise same time working one or tow time
  • 10,594 Answers
There is flexible ribbon wire connected between LCD board and camera board. This wire seems cracked / broken.
You need to replace this wire.
Need further info, let me know.
Posted on Dec 13, 2008
Horizontal blue and black lines
Based on your information given maam, I can say that your LCD is not working well but sometimes it happens that there is a problem on its connection to circuit board..This is usually I encounter maam as a most experienced technician.Thanks.
Dec 23, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
My Sony handycam won't allow me to use the touch screen features in play mode. I can't rewind, play or fastforward the tape. It has reached the end of the tape - what now?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Reinsert the tape and check the operation
Try another tape to check whether the issue persists only with particular tape.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: In the above figure, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Dec 18, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
Picture sides cut off when watching avi files
My new LG LCD is not syncing the video and audio when playing avi movies on either USB stick or HDD.
Dec 28, 2009 | LG 37LC5DC 37 in. LCD Television
VHS won't play correctly - no picture, muffled low voices
Several things.
Check the tape, by opening the cover, to see if the tape is damaged. Look for signs of crinkling at the edges. This is often caused by the roller being worn on one of the VCR.
If it's damaged there's not a lot you can do.
If there's no damage try taking it out of the cassette box and fitting it in a new 'good make' blank tape tape box, discard the new tape in it. Still no good?
Next step, is the tape a movie/tv made by a commercial company. Or a recording on a blank tape?
Did it ever play? (if a movie) if not suspect a pirate tape report seller to FACT.
If a blank tape, try recording on a blank section. If that doesn't work and your video will record on other blank tapes. The tape has something wrong with it.
Some video recorders will play tapes with bad problems IE bad tracking, that others refuse to play, but you will either have to find one owned by a friend or buy one with that claim.
Sep 08, 2009 | Televison & Video
Blank VHS tapes work; Movie VHS tapes don't
Hello statman_4
I have an important question; Are you watching a VHS tape you recorded of another VHS movie? In other words did You rent Ben Hur and record it and then tried to watch the recording? If you did that's your problem. VCRs in the late 1990's (1997-1999) began to employ MacroVision circuitry in all VCRs, and DTR. MacroVision Circuitry makes the VCR record tapes with MacroVision in such a way that the horizontal and vertical sync pulses are not at the proper amplitude, and the AGC (Automatic Gain Control) is tricked into over compensating thus creating the scrambled picture. There is a way around this. You need to buy a video stabilizer SIMA makes such devices and some other companies do to. You feed the signal from your VCR into the unit and it corrects the video image by readjusting the video signal.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Mar 25, 2009 | RCA Televison & Video
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
TV Screen is to dark when playing games or watching movies
turn off enegery saving mode cheak coler britness lock it into your fav user settings on all inputs eash input hdmi has it own coler u must adjust ok to fit needs on eash input k
Oct 08, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Recording from a vcr
check a/v imput on camera settings, make shure that u have audio alsso conected, tried to use diferent output (DVD), make shure is playing .,
Feb 03, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Open Questions:
See all Sony Handycam DCR-HC30 Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC30 Mini DV Digital Camcorder Logo
333 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
