Question about Dell A940 All-In-One InkJet Printer
I get a message that the printer spooler service is a problem
It is a del A940. what do I do? thanks
  • 435 Answers
Please state your problem as a comment as your problem is not fully displayed...
But, as you have given printer spooler service, I suggest you to go to this link, where all spooler problems are given with solution:
Dell Printer Spooler Solutions
Please rate it Fixya, if it helped you...
Thank you
Posted on Dec 13, 2008
My MP250 printer has stopped working.I have tried completing a driver update,but got a message that Printer spooler service has stopped.Start spooler service.How do you do this
That depends upon what Operating System you are using. In Windows 10, you only need to press the CTRL-ALT-DEL keys and go to TASK MANAGER. Select the SERVICES tab. Scrool down to the SPOOLER. right-click and press START (or RESTART) to get spooler back up.
Nov 14, 2016 | Office Equipment & Supplies
OUR tALLY 8008 IS A NETWORKED PRINTER. FOR SOME REASON IT IS NOT PRINTING FROM MY COMPUTER. IT WAS PRINTING FINE THIS MORNING AND IS STILL INSTALLED ON MY PC. THE MESSAGE "THE DOCUMENT FAILED TO...
You may need to clear out your print que and restart the print services. Open a command window by typing CMD in a run box. Type the following in the command window after it opens:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
There will be a delay after you hit enter when you type the net stop and net start commands.
Aug 26, 2010 | TallyGenicom Office Equipment & Supplies
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
All of a sudden my printer is saying busy and won't print
there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 26, 2010 | Dell A940 All-In-One InkJet Printer
Cannot uninstall printer a940 driver. when we try message comes up 'printer in use"
easiest way is to stop the print spooler by going to the run command and typing services.msc then locate the print spooler and stop the spooler. you can now delete the printer driver.
Oct 22, 2009 | Dell A940 All-In-One InkJet Printer
Problem in spooler running
restarting the machine oftentimes saves you time from troubleshooting
Aug 17, 2009 | Dell A940 All-In-One InkJet Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
SPOOLER SERVICE IS NOT RUNNING
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
