Question about Ovens
Change gas oven from natural gas to propane.
I just bought a house and need switch my oven from natural gas to propane.
  • 706 Answers
Hello littelhauler,
Most Oven manufacturers offer a conversion kit for this changeover.. I would contact a local applicance repair shop near you and tell them what you are trying to do as well as provide them with the brand and model of your stove.. They may have or be able to order a conversion kit for you..
Regards,
Rick
Posted on Dec 13, 2008
The wall behind my propane oven is black, why?
possibly the air shutters were not adjusted when new for propane use,most units come set-up to burl natural gas but need conversion to burn l.p. gas by changing the orfices on the top burners,then turning the orfice spuds down on the bake and broil orfices as to control the flow of a heavier gas and also opening the air shutters on these venturi gas feed tubes next to these orfices
Dec 12, 2012 | Kenmore Ovens
Can you converta lincoln impinger from natural gas to propane
Yes you need to go to your gas company and ask them to convert it to LP use they will change burner orfis hrom Natural use to LP use.
Jan 06, 2012 | Lincoln Conveyor Oven - 1133-000-A
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
The oven leaks gas fumes into the house and will "blow up" if not opened every 30 minutes. it forgotten and left on for an hour, it may blow out from under. This oven was converted from natural...
incorrect conversion- valves to large - gas should not leak at all- should only FLOW when in use- TURN OFF GAS TO STOVE- EXTREME FIRE HAZARD
May 10, 2011 | Jade Ovens
Need to know how to convert from natural gas to propane. vulcan oven,.. model 60XL77R. thanks!
I am looking to change from propane to gas. Willing to swap parts
Mar 16, 2011 | Ovens
Natural gas to propane?
You have to get a converter for propane. You can call any hardware store in your area. Hope this helps you, if not, you can call me. :>)
Aug 13, 2009 | Maytag Ovens
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Ovens Logo
178 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
