Question about HP Photosmart E217 Digital Camera
My camera show the batteries are dead when they're fully charged
2 Suggested Answers
  • 4 Answers
SOURCE: my camera hp photosmart e217 turns on with well charged batteries
I had a similar problem with my HP R837. Maybe this will work. It seems to have worked for me, at least for the time being:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00863607&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3319439〈=en
Posted on Dec 21, 2009
Fully charged battery reads as a dead battery in camera.
hi,
it could be a software problem. if the camera doesn't get the battery's information this will occur the center terminal of the battery must be clean, similarly the contact inside the camera.
if it works for a little while, try to reset to default manner.
Dec 30, 2015 | Canon PowerShot Cameras
Dead battery- won't take a charge- it just blinks amber.Do I need a new battery for my Samsung 5x?
Sounds indeed like the battery is dead. You could try checking it with a volt meter. If the volt meter says it is fully charged then you have a problem with the camera instead
May 10, 2015 | Samsung PL20 Digital Camera -Silver...
Can not run netbook off battery even though battery shows fully charged' When charger is removed netboook will not turn on
Make sure the battery is fully inserted and clicks in to the netbook body. Your battery may also be showing that it's charged but is actually dead. Try a new battery and see if it solves your problem.
Jul 04, 2013 | Wolvol Mini NOTEBOOK COMPUTER Laptop...
I have a Sanyo Xacti VPC-E60 EX Digital Camera.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 16, 2012 | Sanyo Xacti VPC-E60 EX Digital Camera
Camera shows battery dead. battery is fully charged. opened battery dor and battery ok. added lens and battery shown as needing charge.
You probably have a faulty battery or charger. If you know someone with the same camera try swapping batteries. If not a new battery sounds like your next move.
Good Luck
Jun 16, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Sony ccyber dsc-w1 battey goes dead very quickly on shooting mode
Your battery life is finished thats why after showing the full charging its dead faster. Buy new rechargable battery , charged it fully and use it. You naver face the problem again.
Thanks.
Feb 06, 2010 | Sony Cyber-Shot DSC-W1 Digital Camera
How can I tell if my battery is dead?
Very often the battery is "not" at fault. The inner contacts within the battery compartment need to be cleaned. Take a cotton swab and "dampen" it with rubbing alcohol and clean those contacts. Also clean the contacts on the battery and the charger, if so equipt. This should solve your problem. Regarding the battery status, the battery icon will show as the charge depleats and so on, if you see no battery icon, than the battery is fully charged. Some cams show the fully charged icon also. Thank you, Dana
Jan 20, 2010 | Konica Minolta DiMAGE X50 Digital Camera
My battery charger shows (green) fully charged when it is dead
THis is really a sign of a bad battery that is always being detected fully charge but its really drian , so it will be better for you to replace that battery.....
Dec 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Dead batteries when fully charged
Does it work with "no batteries" - only plugged into power source? check your usb cable by trying to power up something else.
Jun 28, 2008 | Fuji FinePix S7000 Digital Camera
HP Photosmart E217 Digital Camera Logo
20 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
