Question about Suunto X Lander Military SS012926110 Unisex Watch
The setup button doesnt seem to do anything
I have tried to set time and the units of measurment on my watch but when i hold the setup button nothing happens. the other buttons all seem to do something but when the setup button is held for no matter how long, nothing happens.
i have made sure the mode indicator is on time multiple times, i have even removed the battery and replaced it.
  • Anonymous Mar 15, 2009
    Set-up button doesn't work. The watch is brand new, just out of the box, and i can't even set the time, scroll to the different sub menu's etc.
  • 2,334 Answers
There is nothing to do with battery. You have dirty setting button or oxidized plate contact or weak pushbutton spring. To fix that you have to dismantle your watch.
Take the movement out and clean the pushbutton in case from both sides with tiny brush and lighter fluid (Zippo). Dry out with dust blower. Get small steel pin and clean (scrape) coresponding contact on plate clean of any visible residue. Use dust blower again. Strengthten coresponding contact spring by slightly pulling it outwards. Reassemble watch.
Good luck
Posted on Dec 17, 2008
How do I set the time on my xhilaration watch
press the setup button 3 times then followed by the right side button then press & hold the left side button for 5 secs. May take 3 or 4 tries to get it right.
Jun 07, 2012 | Watches
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
My wife has a Nike Alpha Project watch with new battery. We cannot set the time. I press "Mode" and nothing happens. I hold it down and nothing happens. Perhaps the buttons do not work? Shawn
Maybe the button is not pushing the internal button properly. Undo the back and remove the watch unit from it's case and then see if it works when you press the internal button.
Aug 02, 2010 | Watches
Can't set day and date on cote d' azur watch
Actually I can't solve this. My son bought the same watch on a Carnival Cruise and had the same problem. Upun closer inspection with a magnifying glass, it is obvious that the hands on the day and date dials are fake!! They are just attached in the center to the watch face. The other two push knobs on the watch also do nothing at all. So basically a rip off, but at least it was only $20. At least it keeps time for now. As usual, if it seems to good to be true, it almost always is. Sorry about that, but we are in the same club with you.
Apr 27, 2009 | Watches
My G-shock wavecepter is 1 hour fast. I can't seem to get it to set to the proper time. I live in Oregon on in the Pacific Time zone. My watch is set to LAX. DLS is off and when I tried it on it jump to 2...
This url (below) has a REAL manual for your watch, not the worthless one that comes with the unit.
http://world.casio.com/wat/download/en/manual/
You can type in your 4 digit module number and get a great document that tells you how to operate your unit and some of how it works. (Adobe Acrobat - PDF file)
The solution involves holding down the adjust button until the time zone starts flashing, adjusting with the right 2 buttons and pushing the mode button to get to other options. You then finish by pushing the adjust button again.
Hope that helps. :-)
Dec 05, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Bijoux Terner Sport watch RO616F
I got one of these on a cruise, and I had the same issue, and searched on the web just now (7/26/08 9:20pm) and could not find an answer.....so, I just sat here for a few minutes to push all the buttons...
Mine has 4 buttons at the 2, 4,8,10 positions....corresponding to "start", "reset", "mode", "light"
Hold down the "start", then while holding it down, push the "reset" button.....voila!
Jul 21, 2008 | Cerruti Watches
Sportline watch setting time???
With the watch in time mode, press and hold the mode button for 4 to 5 seconds until it beeps and the digits start to blink. Then press the mode button again to advance through each setting. When finished press and hold the mode button to exit the setting mode.
Mar 15, 2008 | Sportline 1000 Memory watch
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Dec 04, 2007 | Watches
Suunto X Lander Military SS012926110 Unisex Watch Logo
145 people viewed this question
Top Suunto Watches Experts
Ansel Alberto
Ansel Alberto
Andrew Taylor
Andrew Taylor
Are you a Suunto Watch Expert? Answer questions, earn points and help others
