My audiopipe amp went into protect mode randomly. even though i have to prevent fuses on my power wire
Ok, for starters you need to clarify if you are saying you have "two" fuses on your power wire. That's what I get from your statement. My question would be why? As long as you place the initial fuse within 12 inches of the battery, you're cool. The purpose is to stop the flow of power in the event of a spike so that your power wire doesn't fry and cause a fire under your vehicle carpet. Second, your amplifier should have fuses that trip when this occurs too. If this has been occuring since you installed the amp, you need to recheck all your wiring (I recommend removing the extra inline fuse). Two things trigger an amps safety mode. 1- an amperage fluctuation or overload. It will sense when there is to high or too low of an amperage flow. Too much fluctuation can damage internal components. 2- Your amp is malfunctioning. If you have an internal short, this could occur. (really it's tied to the first one because it is sensing that the short is allowing a full flow of power at the short, thus causing a fluctuation). Start with the ground wire. Most amperage problems happen because of a poor ground. Think of power like water. If you have a good flow coming in, but poor flow going out, it gets kinda....backed up. This causes a fluctuation of the amperage since the electrons cannot flow properly. Setting off the protection. The other thing to thing about is the correct guage of wire. If you have too small guage wire, the amperage will dip low during heavy usage, causing the other extreme of the fluctuation.
Check what you have. If you are running a load of 50-65 amp (look at the fuses on your amps and add them up), then 4 guage is good from 13-22 feet. If you are running any higher than that, you will need 2 or 0 guage wire. You will also need to make sure to have a fuse slightly higher that the amperage draw you are expecting. As always, make sure your power and ground wire match. I have seen alot of kits made with smaller guage ground wire. They work of the premise that the shorter distance produces less resistance, thus requiring smaller guage wire. I say why risk it. Always use a multimeter when checking for proper ground placement. Also, if you are going to use aluminum or tinned wire (trust me, it's out there), you will need to increase the guage of the wire.
Happy hunting
Aug 14, 2011 |
Audiopipe Car Audio & Video
