RCA model P61950
Screen is bowed top and bottom,convergance option is gone off menu, I read it's fuse fl231but cannot locate no such fuse, I also read its on or near the flyback but dont know what and where that is either.
  • l_f_g_78 May 06, 2009
    the convergence menu has dissapeared all together,and screen is bowed in on top and bottom
  • 19,396 Answers
Fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Posted on Dec 13, 2008
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Were is the convergence board located on my tv
The convergence is split between 4 different boards on the rca itc222 model. depending on the symptoms of the picture will determine which one is at fault. What does your picture look like? is it bowed in at top and bottom? Is the picture 3d can you see red blue and geen? When you go into customer setup menu do you see the convergence options. if you see these what effect do they have. Let me know and i will help you isolate the problem....DOnt know but it could be the common fl231 fuse problem. read this to see if you do and let me know how i can help http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca hd '52" tv has a bow in it & colors dont line up
Blowed Fuse FL231 will be on right handside of FBT flyback Transfomer there is 3 of them in a Roll small brown looking caps But they are Fuses it will be the one in the Middle Located on your Deflection Board which is the Bottom left hand side Board. www.Partstore.com for Fuse
Dec 21, 2009 | RCA HD52W59 HDTV Projection Television
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Autoconvergence option is GONE!
You will need to replace the ITC222 convergence power supply board and the FL231 fuse on the deflection board. You can get replacement parts at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Sep 24, 2008 | RCA R52WH73 Projection Television
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Televison & Video Logo
333 people viewed this question
Top Televison & Video Experts
