Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Problem with mitsubishi air roof units
I have purchased and installed two mitsubishi multi-split systems (MXZ-A series) for my home's heating/cooling.
To one of them, 3 roof units (SLZ-KA35VA) are attached.
The problem:
While operating in heating mode, the roof units, will not operate: power is turned on, but the fan with hot air does not work. It seems to be in standby mode...
This happens, even though I set the desired temp. to be at 28 degrees, while room temp. is at about 20. It seems the thermostat 'thinks' the temp. is much higher...
Indeed, placing a thermometer at the gill of the unit, it read over 27 degrees (while room temp. was about 20 degrees).
What can I do about this?
My dealer cannot help -- simply suggested to set desired temp. as high as possible...(28 degrees is the highest, meanwhile...).
Is there any way that the thermostat can be 'fooled'/tricked.
What I do now, is switching the operating mode (from heating to auto, cool, and then back to heat). Then, somehow the fan starts blowing hot air out...
(I guess because cooler air blows when in cooling mode, and the air around the thermostat is cooled)...
Any other suggestions?
I would sincerely appreciate any help.
  • 407 Answers
The thermostat would need to be insulated better from the air that is surrounding it. Im assuming that the thermostat is located on the wall unit where it blows out the air. This could mean that it is actually reading more from the outside temp, than whats inside the house. Another thing to consider is the location of the thermostat, even it being close to anything in the house that produces some kind of heat will effect the condition of the air. If anything, its the manufacturers mistake if it was properly installed in the first place and if defective, they should replace it. hope this helps.
Posted on Dec 28, 2009
    Habit-Forming:
  • 109 Answers
To tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Posted on Jul 09, 2009
What is the difference between a ducted and non ducted Domestic Air Conditioner?
Ducted A/C has an internal fancoil unit installed in the roof space of the home. From this central location, a series of ducts run from it and into as many rooms in the house as the owner desires. From these ducts, this allows you to cool or heat each room individually – called zoning
Split systems stand out for their relatively low initial purchase price. Another perk is that the installation is not so invasive – it can often be done in a day or less from a licensed technician. Though, being that the unit is fairly small, it is best suited to cooling or heating one room – this is either a positive or negative depending on how you look at it. On one hand, it’s an efficient option if you only need to cool or heat one room, but on the other hand they are less effective in larger spaces. Rarely could a split system air conditioner cool or heat an entire home. Split system air cons are great options for small areas, but lack the power to affect larger spaces – this is reflected in their relatively cheap purchase price, from around $1,000-$2,000.
Aug 05, 2017 | Heating & Cooling
Tip
Ductless Heating and Cooling of the Hard to Duct Home
You are <b>building a log home</b> or a home that you want the rustic look of the <b>floors above also being the ceiling of the floor below</b>. You hate the thought of having to install ugly <b>heating and air conditioning ductwork</b> in your new home. For you there is hope. You can still have a comfortable home and have the look that you want.<br /> <br /> The advancements in <b>ductless heating and cooling</b> has made it possible for you to have those wood ceilings, roof lines, wood walls, and everything you can think of. The new <b>ductless HVAC units</b> take up very little space on your wall. They can be placed almost anywhere with a little planning, and they are<b> very efficient at both heating and cooling</b>.<br /> <br /> The many features do not stop with the<b> heating and cooling</b>. Most units have remote controls to run the unit. Many of these units can run <b>multiple inside units from one outdoor unit</b>. These units are so quiet that you have to feel the air coming from them to see if they are running. The installation has been simplified to the point that they can be installed very quickly by an <b>experienced professional</b>.<br /> <br /> If you are concerned about the looks on the outside, that too can be fixed rather easily. The <b>piping and wiring going to the indoor units</b> is relatively small and can be hidden in many ways by using a little imagination. Colored aluminum can be fabricated to cover the pipes. I have also run the piping through rain spouting and made it to look like just another rain spout coming off of the roof. <br /> <br /> If you are looking to build or remodel and are worried about the look you will have on the inside, then take a look at <b>ductless split heat pumps</b> to give the comfort and the looks.<br /> <br /> Good<b> heating professionals</b> can find many ways to make these units work for you. Make sure that you do not settle for something less than you want. You may need to look at more than a few companies to find the one that will give you the system that you want.
on Feb 19, 2011 | Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
I am not able to get the unit to change from air conditioning to heat
Unfortunately these units are not user fixable , beyond checking for power and checking battery in remote. You would need to call a pro who is able to get service information and has special digital logic meters to diagnose and repair .
Oct 04, 2014 | Mitsubishi MXZ-2B20NA-1 Mr. Slim Dual Zone...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
E 7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2), Check loose wiring/condenser coil for clean
Jan 10, 2011 | AmcorAire UCHW-H24AF2 Split System Air...
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 24, 2010 | Mitsubishi MS09TW Air Conditioner
Split system outside unit won't come on for cooling, only heating
Check your filters, dog hair and lack of maintenance will definitely burden the cooling mode of the Mr Slim units.
Aug 22, 2009 | Mitsubishi Heating & Cooling
Power light is flashing and it isnt working
A multi split system is it? One of the reasons why the light flashes is because one indoor unit is on cool and the other is on heat. Changing the one on cool (or on heat) will fix this. Both indoor units need to operate on the same mode.
Mat
Jul 20, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
1,094 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
