Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Ultimate Care II Whirlpool Washing Machine (top loading) - same problem as everyone else. 4 years old - gets to the final spin cycle and just "whirs." It appears that the door switch is working. It clicks when I close the door. It appears that all these machines fail at 4 years of age. There are only 2 in the household and we do 2 loads a week. This should not happen. How to I disassemble the machine to see if the belts are worn or broken. There were times over the past few months that sheets got tangled in the agitator. Whatever you can do to help. Thank you. Just want to know how to perhaps solve the problem before I add it to the junk pile.
  • judithlahey Dec 14, 2008
    To clarify my problem:
    When the machine got to the end of the washing cycle, it just whirred. It did not empty the tub and it did not spin. I tried it on different cycles and it did the same thing. I believe that the catch on the top lid is okay but how can I tell for sure. It clicks when I close the lid.
    What can you suggest? I would like to try to fix it but I would need a schematic or manual to try it myself.
  • Steve Hlavka May 11, 2010
    what problem are you having
  • 85 Answers
It sounds like you have a broken motor coupling. disconnect power supply unscrew 2 screw on each end of backside of control panel, flip control panel to back, remove lid swt connection and pry up the 2 clips that hold cabinet. remove cabinet, on bottom of front you'll see the pump and motor. pry off the 2 clamps that hold on pump you can tie pump to side to keep out of you way don't disconnect hoses. remove 2 1/4 in screw that hold clamp to motor and remove motor clamps pull mtr to front and pry off coupling from shaft of mtr and transmission.replace coupling pn 285753a for about $10 .reverse procedure to install
Posted on Dec 14, 2008
Will not spin
The final cycle of any washing machine, including Whirlpool units, is the spin cycle. During this cycle, water is sucked out of the load, preparing the clothes for the dryer. If your spin cycle isn't working properly, your clothes will be extremely wet, which increases the length of the drying process. Troubleshoot, and repair this problem yourself to save money
Jul 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine top loader will not rinse or do final spin
If your machine fills and agitates through the wash cycle and then stops, check the lid switch.
http://www.youtube.com/watch?v=bV8C6aLBL9w
Mar 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Have a 10 year old Whirlpool Ultimate Care II top loading clothes washing machine. In the "Delicate" cycle, it stops after agitating sometimes and will not kick into the spin empty part of the...
Yes it is a timer issue, and yes the whole timer will need to be replaced. If you are handy it is not very hard. You can order the timer from marcone.com with your model # and it will show you a parts breakdown so you can see hoe to replace it easier
Nov 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Super Capacity Plus
BETWEEN THE MOTOR AND TRANSMISSION THERE IS A COUPLING THAT SERVES AS THE BELT PART # 285753A REPLACE THAT WILL SOLVE YOUR PROBLEM
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
