Question about Toshiba TP50H50 50" Rear Projection Television
Toshiba TP 50H50 Blank Screen
I have an older Toshiba TP50H50 projection TV. I bought it back in 1998, and figured it would need maintenance soon. Just recently, the screen went dark with the sound still working. I figured it would be the bulb burnt out. Does this sound about right? Also, do you think it would be worth it to fix this issue or just replace the set? Thanks.
    Sergeant:
  • 308 Answers
IT sounds like you lost your high voltage going to the picture tubes. This could be due either to part of the main power supply going out due to a defective capicator or semiconductor, or something more serious in the High voltage distribution network. With the age of the set, I would be most inclined to replace it with a new HDTV, and Toshiba still are pretty reliable sets. If you can afford it, a Sony KDS-55A20 puts out a beautiful picture for around $2300.
Posted on Mar 12, 2007
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
I need a new screen for my toshiba tp50h50 rear projection tv
srobinsota,
Available at http://www.encompass.com. I have a tip at http://www.fixya.com/support/r6210638-replace_broken_projection_tv_screen which should help with the removal and replacement procedure.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 08, 2011 | Toshiba TP50H50 50" Rear Projection...
Tp50h50 toshiba 50 in tv i need a part number for the screen behind the plastic screen this would be the center screen and where i can get one
Part number should be 23837513.
Checked four different distributors and as far as I can tell none of the screens for this television are available. If you are handy with a tape measure and have a screen bigger than yours from another set you can cut it down to fit. Just measure from the corners to find the center then measure out to the dimensions you need to replace the old one.
Jul 09, 2009 | Toshiba TP50H50 50" Rear Projection...
TP50H50 Screen Broken
The Toshiba part number is: 23837513
But it is listed as no longer available .. all you can do is call parts dealers to locate
Jan 05, 2009 | Toshiba TP50H50 50" Rear Projection...
Screen
Try this link, leave them an email but you will need to measure your screen size top to bottom and side to side just the visible screen area then leave them a email at the site they will get back to you soon.
http://servicemanuals.vstore.ca/
Jun 20, 2008 | Toshiba TP50H50 50" Rear Projection...
Broken Screen
the only fast solution is to go to an authorized TOSHIBA dealer repair shop and have it order it , warning the screen is expensive as I found out when I needed one too ( i own a 55" TOSHIBA ) it could cost around $200.00 up to $400.00. hope this info helps
Apr 25, 2008 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP50H50
Hi There!
I am not familiar with this model,however if there are no screws or clips on the inside or side panels, the front would be the place to start. usually right at the bottom front are screws to remove the bottom front panel first. Then the rest will be exposed. Work your way from the bottom up. The screen itself will be last and normally hooks over the top frame. Good Luck, JUS004
Feb 26, 2008 | Toshiba TP50H50 50" Rear Projection...
Toshiba 50H50: No picture or sound, red light blinks
On alot of these Toshiba TV sets, there is a fuse called F860 that will blow and the light will flash because of bad solder connections on C 810, and C 809, on the negitave terminal. I have seen many of these boards condemed by non-authorized Toshiba repair shops. Good Luck
Jun 04, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP50H50 50" Rear Projection Television Logo
156 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
