Question about Microsoft Xbox 360 Console
Whenever I try to turn on my Xbox 360, a red light comes on the plug in thing HELP!
  • BUNDFUSS Dec 13, 2008
    red light is on on the power pack unit is dead, before trying to restart the wired contoler was having problems conecting to the unit as it was saying reconect the controler.
    Please can somebody help as my boy has asked santa for lots of goodies for his xbox 360 but now it is broken.
  • 116 Answers
Have you called the microsost tech support? the power pack may be failing, they can help you find out why or you can go to the 360 website and use the support system there.
Posted on Dec 13, 2008
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
Xbox 360
It's overheating. Consider buying an external cooler at a local Target or Best Buy.
Jun 08, 2009 | Microsoft Xbox 360 Console
Ive tried the 3 light fix for the xbox 360 it keep shuting down
Make sure you have all the clamps on the chips tight. If one pops loose it will cause this.
Jan 13, 2009 | Microsoft Xbox 360 Console
Red Light on Plug in connecter thing
Sounds like there is something wrong with the Xbox 360 power supply, try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord. Give it a minute then reconnect it all back, also try it on another wall outlet without any extension cord at all.
If it's still red that suggests fault with your Xbox 360 power supply so will need to contact Xbox 360 customer support if its under warranty they should be able to sort it out for you. If out of warranty it might cost you for a new power supply!
Dec 13, 2008 | Microsoft Xbox 360 Console
XBOX 360 - Games will not play -
a red light appears instead of green
Jul 13, 2008 | Microsoft Xbox 360 Console
Xbox 360 wireless network adapter
Turn off the console. Take out the adapter and plug it into the ports on the front of the xbox 360. if this doesnt work, you will need a new on.e
Jun 23, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360
Whenever mine wouldn't read disks i'd hit it a few times on the top face (lower left side above dvd drive), then turn it back on to see if it would read it. Sometimes i had to do it 5-10 times... and eventually it worked again for a few months.....
if that doesn't work I'd Call xbox 360 support and see if they will fix it for free (they are fixing the 'flashing red lights" error for free right now... possibly your disc read error). if they refuse to fix it for free and you don't feel like paying...... wrap the damn thing in a towel and power it on (keep it in eyesight as you don't want the towel to catch fire)...do it for like 10min-30min whenever you geta chance.... eventually the processor will over heat (due to lack of airflow and you will have three flashing red lights when you turn it on... and your 360 won't work at all.... (and microsfot WILL FIX THAT PROBLEM FOR FREE... and hopefully fix your drive too ... wink wink)
... of course... .wrapping your 360 in a towel (known as the "towel trick" will harm your xbox more... and i'm not taking responsibility for what happens to you or your xbox) might not be the best idea.... but it may just get you a free repair =)
Jan 07, 2008 | Microsoft Xbox 360 Console
My xbox 360 power cord box messed up....
check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
Jan 06, 2008 | Microsoft Xbox 360 Console
4 red lights
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
