The dashboard lights are out such that you can't see the dash at night when you turn on the headlights. Replaced bulb, but should have checked fuse first.
Just use a digital multimeter and check the resistance across all the fuse s if one of them is ofl then it has an open it that fuse
I have reasons to believe that my fuse boxes were tampered with by the guy that installed a new radio. After the installation, the dash lights along with taillight, break light, reverse light, and dome lights were out. After I had reason to be suspicious, I checked the fuse boxes and found five dead fuses between the two fuse boxes. I replaced them and everything is working except the dash lights. I noticed that there are two empty slots for relays on the fuse box by the petals and I was wondering if the guy simply removed the relays. That is why I need the fuse box diagram. Thanks for your help.
SOURCE: My headlights just won't turn
sounds like your head light switch took a ......go to napa and buy another one and change it out if you can't do it yourself i live in chicagoland area good luck
SOURCE: I need a diagram of
The fuse for your tail and dash lamps is "dedicated fuse" #2 in the engine compartment fuse and relay box. It is a 10 Amp fuse. (see picture)
Please also review this article:
Where's The Fuse?
SOURCE: There is condensation in the
Drill a small hole at the bottom of the lens. This will at least let the water drain.
SOURCE: 1999 mitsubishi montero sport cruise control issue.
possible bad speed sensor, get computer codes
