Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Bosch AQ125BNG gas water heater
My water heater all of a sudden stopped working. It will only produce a luke warm water. When it comes on, the flame doesn't seem to be as big as it used to be. also, the thermostat doesn't seem to adust the water temperature at all. any ideas? thanks, Justin
  • hema18 Feb 06, 2009
    My Bosch 125B tankless water broke yesterday. It's not giving hot water, instead cold water is coming. When I turn the tap for hot water, I don't see the gas supply to the water heater.
  • 25 Answers
First thing I would do is clean and rebuild the watervalve. The watervalve on this heater mandates everything. This watervalve has a maintenance schedule in the manual. She be rebuilt every 3 years. Also sounds like the diaphram in the watervalve may be damaged.
Posted on Jan 19, 2009
  • 44 Answers
Hi Jason, it sounds as though you have a gas supply problem with it, now that could be due to a gas valve problem on the heater or a low pressure problem at the gas meter, 1st instance you should seek a Corgi engineer who will diagnose the prob if its a supply problem then you should contact your gas supplier, who will probaly change the gas regulator.
If its the gas valve it could be sticking or a blocked burner injector. This can be tested by the engineer with a manometer gauge which measures gas pressure. if there is a flow prob the thermostat will not function properly.
Hope this helps
Posted on Dec 15, 2008
My hot water won't heat up the flame come on but the water is luke warm to cold
Hmmm. Those btu's have to be going somewhere.
Is the flame turning off too soon? A gradual problem or did the unit suddenly start acting up? Sounds like a thermostat issue and not a particularly difficult job with YouTube guidance.
Apr 13, 2017 | Water Water Heaters
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
Call service technician./ Call Bosch
Oct 14, 2014 | Water Heaters
Luke warm water
is the water temperature dial turned up? or even functioning?
Jul 28, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
Atwood gc10a-4e only producing luke warm water
make sure bypass on back isn't open or half open then see if mixing valve on shower or outside shower off if all ok possible bad temp sensor
Feb 19, 2013 | Atwood Mobile Products Atwood 10 Gallon...
My gas shower is either luke warm or very hot whats wrong
If all the other faucets work, then the problem is the mixing valve in your shower. You will need a new shower fixture.
Apr 10, 2012 | Bosch Water Heaters
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch GWH 425 HN Tankless Hot Water Heater...On 2/28/2010, it began intermittant exploding when demand for hot water occurred. Local technicians worked on the unit several times, changed and...
I have the same problem with the same model. The problem has been identified by a friend of mine, correctly, I think.
This is a very dangerous problem involving Bosch's much touted safety feature, ironically enough. IT IS THE FLAME SENSOR IN THE GAS VALVE. The flame sensor is supposed to confirm that the pilot has lighted BEFORE the main gas line sends gas to the main burners, after which the pilot shuts off. The pilot light is not coming on, the sensor that shouldn't let gas fto the main burners is failing and the main gas is flowing and ignighting from the spark that is supposed to light only the pilot in a big explosion.
This is the 2nd unit of this model that has failed. I think Bosch should do a recall
Apr 25, 2010 | Bosch & Tankless LP Hot Water Heater
Aquastar 125b ng: after 2 years of use water is not hot enough
Sounds like hard water. Service the water valve. Parts are available from your local Bosch Service Provider (Contact Bosch if you don't know who the service provider is).
Feb 03, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Water will not stay hot
The cold main water pressure is too low to maintain a constant flow. Make sure you have no other appliences on, or your not comprimised by the lowering of pressure
Jul 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
No hot water
if the leak is behind the handle take the handle off and tightn the packing nut, do not over tighten, as far as luke warm water is this with just one facucet on, they way these tankless water heaters work they are by gpm, gallons per min, if you have more gallons of water going thru the unit then it is designed for then it won't get hot, if your water pressure is to high going thru it will push it to fast thru the unit and won't get hot, your house pressure should be no higher then 75lbs no lower then 65lbs
Feb 25, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
2,382 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
