Question about Sony VAIO PCG-K23 Notebook
Hard Drive failure predicted message.
Error message hard drive failure predicted
  • Sony Master
  • 4,806 Answers
Hi there
your hard drive is getting ready to fail, you must back up all of your data straight away before the drive crashes and you loose all of your docs, music etc
kind regards and please don't forget to rate us
Posted on Dec 13, 2008
  • 116 Answers
Back up your hard drive, get a copy of everything on it, pull the hard drive out and find out who manufactured it, most harddrives have a very extensive manufacturer warrantee, and you can get software to test it from their website and claim the warrantee on it. Imaging your hard drive to another is an option. I can help you with this if you like, just let me know.
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
SMART Failure Predicted on Primary Master QUANTUM FIREBALLP AS20.5 Arturo Sghedoni
This error message is a warning that the hard drive may fail in the near future. It is advisable to backup your data frequently so that when the hard drives fails you will not lose your data.
Oct 14, 2010 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
Acer 1642 laptop is giving me much trouble. Was working fine until, fapoot... now i receive a message: SMART failure predicted on hard drive 0:ST6100825A-(PM), please help if you can
A SMART failure means that your hard drive is predicted to fail
soon. Fortunately these warnings are not right 40%-50% of the time. Go to the command prompt (start- run- type in "cmd")
In the prompt type in "chkdsk"
This will run tests on your hard drive and tell if there is anything wrong with it.
Dec 28, 2008 | Acer Aspire 3610 Notebook
Seagate 100GB Hard Drive for notebook SMART failure
Solution #1 is grossly incorrect. The S.M.A.R.T. mechanism is software/application/drive content agnostic. It is a firmware-based predictive failure feature. If the S.M.A.R.T. test returns a certain bit, then the drive is degrading and in need of replacement. If the disk is under warranty, then it generally qualifies for free replacement. If it is not under warranty, then you can run diagnostics such as http://www.santools.com/smart/unix/manual which can sometimes identify the specifics. Sometimes the problem is transient, like the disk was powered on/off too many times in a short amount of time, or the temperature is too high.
May 25, 2008 | Computers & Internet
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Error message at startup !!
SMART stands for Self-Monitoring, Analysis, and Reporting Technology.
If you want lots of details on what it is, and does, take a look at this link:
http://en.wikipedia.org/wiki/Self-Monitoring,_Analysis,_and_Reporting_Technology
It is highly unlikely that you will be able to fix this since it's a hardware problem on the hard drive. The drive may last for years or it may die tomorrow. At a minimum I would back up everything you care about on a regular basis.
If you found this information helpful I would appreciate it if you would rate this solution. I hate to beg, but over half of the solutions I've posted have no feedback. I'm not paid for this I'm just trying to help.
Dec 31, 2007 | Computers & Internet
Predicted hard drive failure
Sounds as if it's the end for your hardrive, although check it'd connection to the motherboard is ok. If you check you hard drive manufacturer, it may have a 3-5 year warranty period.
Oct 31, 2006 | HP NX9008 PC Notebook
Sony VAIO PCG-K23 Notebook Logo
111 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
