Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
Power Wheels barbie jeep wheels slipping
When the gas is pushed the wheels on the back of the jeep slip. The teeth are not in the grooves. How do I fix this?
  • 3 Answers
Ihad 1 for my son the solution is if you have plastic whells i to screw somme screws in the whells you get better traction it workt for me dench
Posted on Apr 01, 2009
My granddaughter's barbie cruisin' tunes jeep only has fast gear, no slow or reverse.
check and see if both wheels are spinning, if not you have a bad motor which would cause the other gears to not work
Jun 24, 2014 | Fisher Price Power Wheels Barbie Jeep
Change the tire on barbie jee
pop the hubcap off with a flat head screwdriver, then use a vice grip and pinch the metal push nut in half then remove
Sep 23, 2012 | Fisher Price Power Wheels Barbie Jeep
Need instructions for assembly of power wheels barbie pink jeep
those are the traction bands, they go around the wheels, there should be four of them
Dec 25, 2011 | Fisher Price Power Wheels Barbie Jeep
Broken barbie-kelly doll power wheels
You have to push the horn to make it go. I had same problem. Gave to hubby to look at, He had it going in minutes.
Dec 24, 2011 | Fisher Price Barbie - Kelly and Tommy...
My daughter's barbie power wheel jeep keeps slipping out of gear and won't drive.
make sure that the cogs on the tires are in tight contact with the drive motor, you might have to add some washers to take up the free space
Oct 06, 2011 | Fisher Price Power Wheels Barbie Jeep
Is there a way to remove barbie jammin jeep wheels without breaking the parts holding the wheels on?
Sorry to tell you but in order to remove the wheels from the "Barbie Jammin Jeep" wheels the parts holding the wheels on would actually have to be removed. The Jeep is made mostly of plastic that has been "molded to fit" meaning that trying to remove the wheels would be a big problem unless you intend on decommissioning the Jeep and it's parts.
Jul 29, 2011 | Toys
Hello, with all 4 wheels off the ground,engine running and in gear only 3 wheels are turning. The right front does not. is this normal?
Unless you have a positraction rear differential, I'm surprised that even three are turning! Four wheel drive is really two wheel drive because both differentials are "open" type. In an open diff, only one wheel has power at any given time. With a positraction, or "limited slip" rear diff, both rear wheels push with fairly even force but the outer wheel is allowed to slip when going around turns. Only true four wheelers have either a limited slip on both ends or "locked" units but it is impossible or really difficult to drive anything like that on the street. If you hold the left front wheel from turning unless the locking unit is broken, the right front should turn.
May 10, 2010 | 1998 Jeep Grand Cherokee
1997 yamaha timberwolf 4 wheel drive only front wheel drive work
check to see if driveshaft to rear is turning.if it is, either the ring gear & pinion gear in the differential are not making good contact either from being worn, or out of alignment due to worn bearings in differential case,or both.check if axle has back & forth play in differential,indicating worn beaings. also could be worn ring gear to axle contact in differential.check for vibration in axle while in gear increasing as you give it more gas, caused from ring gear teeth slipping past teeth on axle.they would have to be replaced together. oversize wheels & tires tend to accelerate axle/ring gear contact teeth.
Feb 16, 2009 | 2003 Yamaha YZ 250
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
382 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
