Question about Toshiba TN50X81 50" Rear Projection Television
I have a TN50X81 TV with no picture on any inputs
When I turn on the tv the screen will flash white for a second and I can see what input being used and the channel the tv is on, get full sound but no picture have called for a tech but by the time he comes to the house the picture start to work again. It will work for couple of months but then it will go out again.
    Master:
  • 479 Answers
There is some shorttracking which didables some components from working temporarily creating this problem.
Posted on Dec 13, 2008
  • Toshiba Master
  • 19,396 Answers
Check all the cables and connection, ensure this is not just because of a broken contact in the cable.
  • Ginko
    Ginko Dec 13, 2008
    If the TV turns itself off completely, with no power and no led light, same as if the power cord was unplugged, then this is either a defective power cord or power adapter.
    If the TV goes on standby state and does not restart, then tv is on protect mode, and this happens when a fault is detected. This means that there is a defective component that is failing only under determined circumstances.
    If the AC networ is unstable, then that can be the cause for the TV goin off. In this case you restart the tv by leaving power cord unplugged for a while. this can also be tested by a technician.
    Call the technician the same and have the fault fixed, before the problem excalates and you get more damage to the TV set.
    If you are in case A, the technican will test power board, and easily spot and repair the fault, usually this kind of problem can be caused by a defective capacitor on power board.
    If you are in case b, it may be more difficult for the repairman to find the fault. This kind of faults are often caused by a faulty IC( for example defective convergence ICs) or a faulty component on one of the internal boards, and it is usually more difficult to locate the problem.
    If yo
Why can't I get the DVD player to work? I have it hooked up to a cable box.
im wondering why you did not connect it to the tv ?? but instead to cable box , does it have a pass thru capability ?? does it need to be off to pass thru ?? as most dvd player don't have a rf output but instead use a hdmi or composite signal output , would it not be easier to connect one of these to a spare input on tv then when u want to use dvd you only need to select the proper input from tvs source button to view the dvd ??
Jan 10, 2017 | Sylvania Televison & Video
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
Connect proscan to pc
You can only do this if the TV has an input for the computer, it would be the "RGB" in video input options menu of the TV.
Jan 09, 2017 | Proscan Televison & Video
LG 55LM4600-UC LED TV I have was squirted with a squirt gun. Would replacing the t-con board fix this tv? Please read further details.
when water shorts out something it overloads a lot of other components so the best advice is to take it in for a proper diagnosis.
you just replace a board but another board is damaged it might just blow the board you replaced and that would prove nothing
Jan 09, 2017 | LG Televison & Video
I have a rca model led65g55r120q tv flickers and no sound
Check all cables for loose connection, try another input for picture (DVD, BLu-Ray, etc). If none of the other inputs work then it's a panel problem (display) If one or more of the others work then it's a problem with either the tuner or the signal.
Jan 02, 2017 | RCA Televison & Video
I have sound but no picture on my tv
This is a popular question. Most of the time you either need to make sure all connections are not loose or just need to turn off your tv and receiver and unplug. Wait for 1 minute then reboot.
I recommend this short video as it walks you through some diagnostics for other possible problems.
Repair TV With Sound But No Picture
Nov 24, 2015 | Luxor Televison & Video
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
50" LG Plasma Screen TV does not have any sound or activity on the screen.
input correct ? eg:HDMI 1 USE MANUAL TO GET INTO SETUP MODE.go through all settings.check the contrast and brightness buttons n the TV if any on back or top.
Apr 15, 2013 | Televison & Video
Akai PDP4206EA lost tuner and video inputs
Mine died after a brown out. It turned out to be the main board. They're pretty hard to find.
JE
Aug 14, 2009 | Akai PDP4206EA Television
TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Jun 25, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Toshiba TN50X81 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
