Question about Whirlpool GBD307PRS Stainless Steel Electric Double Oven
Need to verify/reset oven size on a Whirlpool 307PVS double oven.
Replaced the electronic package and now both ovens are cold - suspect the size is calibrated incorrectly.
Found the electronics package manual on another web site and downloaded it.
Posted on Dec 15, 2008
Oven is displaying F01 complaint. I have no manual to see what this means.
Hello & Welcome to FixYa
F01 error in your whirlpool double oven means a bad electronic control board that needs replacement. Please get back if your need more help.
Kevin
Oct 25, 2011 | Whirlpool RBD305PD Electric Double Oven
I just replaced the control board on this whirlpool double oven. It powered up fine but then went to an error code E1 F2. I've double checked all connections and they are fine. Is there a reset...
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch).
Jan 29, 2011 | Whirlpool RBD275PD Electric Double Oven
No response to touch pad. No display or lighting. Check breaker and replaced circuit breaker.
Inside the control panel is a bullet fuse. This thing melts when temp inside control exceeds safe levels to keep from harming electronics.
I have a Whirlpool double oven service manual with
repair photos that shows how to get into the controls:
Whirlpool Double Oven Service Manual and more
Dec 26, 2010 | Whirlpool RBD276PD Electric Double Oven
RBD305PDS14 The top oven of this double oven is not baking or broiling. I replaced the baking element and still no go. Bottom oven is fine. Any suggestions?
Perhaps item number 37 has opened (died) killing the circuit to the elements from L-2. Looks like it $35 bucks.
Better verify it is bad before ordering. Now I know the following video ain't a bult in oven but I want you to see how important it is to turn off power to this oven before attempting repairs:
Sep 27, 2010 | Whirlpool RBD305PD Electric Double Oven
Electronic control panel black out
it may have back lite lcd display and the lights have blown shine a torch into the lcd if you can read it then you need the backing lights replaced
Apr 21, 2010 | Whirlpool RBD305PD Electric Double Oven
Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Mar 12, 2010 | Whirlpool RBD305PD Electric Double Oven
I have a double electric Whirlpool oven and it quit working - the control panel is black - I can't get it to come on at all.
I think Whirlpool and Jen Air use the same display board, It's worth a check anyway.
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Nov 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool GBD307PRS Stainless Steel Electric Double Oven Logo
238 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
