Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Are the heater coils supposed to stay bright red the entire cooking time when broiling?
  • 1,543 Answers
You posted under a JGBP90 GAS Kitchen Range.
If you have an electric range, you should leave the door set to the part way open position (about 4 inches) when broiling, and the top (broil element) normally stays red hot the entire time then.
This should be a Fix-Ya for your problem.
Posted on Dec 13, 2008
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
What should the voltages across the elements in an oven be when using the different settings?
The heating element is either off or on and it should be 220. The issue you are having is the thermostat.
Mar 09, 2016 | GE Ovens
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
Large oven in dacor dual oven range broiler comes on when i select bake
on bake both bake and broil will come on the broil shuts down around 260 deg
this is normal its done to shorten preheat time
Jun 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Coils Stay On When Dryer Is Not Running
This is definitely a safety issue and should be referred to Sears. There may be a corrective repair that can and should be made.
Nov 18, 2013 | Kenmore 60172 Electric Commercial Dryer
My dryer is turned off while runing
It is not supposed to stay burning all the time, only in 30 second intervals or them clothes would be cooked. If it works a little and quits then that is an easy fix. bad coils The coils on all american gas dryers are basically the same part. Here is my video of how they work and what goes wrong:
Dec 27, 2012 | GE DNCD450GA Gas Commercial Dryer
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
89 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
