Question about Epson Perfection 1660 Photo Flatbed Scanner
Red vertical line through images
I really like my scanner and don't need to buy a new one. But my scanned images have acquired a red line through the centre of them, which is a real pain to clone out each time. Can I buy a new bulb or something to correct this problem?
  • 29 Answers
This issue does indeed sound like a bulb issue - however, it would be cheaper to replace the scanner rather than service the unit.
Posted on Sep 10, 2007
SOURCE:
Black vertical line on scan
Usally this is due to dirt accumulated on the glass surfaces of the scanner.
Make sure that both glass windows inside the scanner are clean.
Next step is to clear both CCD's (read heads) but in this case you need to disassemble the scanner.
Oct 17, 2014 | Fujitsu fi-5120C
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
Vertical line down the scanned image
Clean the glass with Isopropyl Alcohol. No solvents please
Mar 11, 2010 | Canon DR-2050C Path-Through Scanner
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Scanner gives poor quality scan...bulb?
I have one with the same problem. Look at the lamp. If it isn't really bright, that could be the cause. Mine is bright at one end and that is the side of the page that is good. I am not an expert so I could be wrong, but that is where to start if all else looks OK. Am looking for a cheap replacement lamp myself. But at the prices of all-in-ones, it's not worth spending much.
May 26, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Lines across scan
It appears to be a freak problem. The best way is to bring it to original condition. Try uninstalling the scanner, run Scandisk on the Comp, Switch off and reinstall the driver. this may work.
S. Mohan
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Red vertical lines, scanning to computer
I had one red line appear when i used the duplex. I happened to notice that the thinner glass window on the scanner was dirty. I cleaned it and now no line appears.
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canoscan 9950f red line on scan
Try running a calibration. This is done thorugh ScanGear in Advanced mode. Once in Advanced Mode, in the Image Settings section there should be an option for Calibration (you may have to scroll down in this section to see it). After running the calibration, try performing a preview scan with nothing on the scanner glass. If the red line shows up on the preview now, then most likely the scanner needs to be serviced.
Mar 12, 2008 | Canon CanoScan 9950F Flatbed Scanner
Red image
the problem could be the cabling between the scanner and the Computer itself.
Other than that the lamp is possibly faulty or on the way out.
try uninstalling and re-installing the scanner.
Also check that the AC adaptor is,nt overheating, unplug for an hour and then retry setting it up.
Mike @ Compurepair.
Feb 22, 2008 | Visioneer OneTouch 9220 USB Color Scanner
Epson Perfection 1660 Photo Flatbed Scanner Logo
500 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
