Question about Whirlpool AWM5125/1 Front Load Washer
How do you remove the back cover off a washer ( whirlpool) I need to get to the level switch. The water will not stop filling. Thanks, Dave
    Problem Solver:
Try undowing the nuts and lift the back cover upwards before removing some backs have little hooks on them
Posted on Jan 20, 2009
Whirlpool 'quiet wash plus' top load washer
the washer is over filling because the float part is bad see the link below for details Whirlpool Dishwasher Overflows Replace Float W10345285
Jan 07, 2018 | Washing Machines
My Whirlpool washer fills up but won't stop poring into the washer. Is this something that is repairable?
Your water level switch could be defective. This switch has a plastic 1/4 hose connected from your tub to the switch. (should be easy to find.) Make sure this hose is connected to your tub and switch and the line has no holes. It is easy to test the switch by disconnecting the line from the tub and while water is flowing into your washer, Blow into the line. The pressure will stop the water flow. If not, Bad level switch.
Level switch part# W10339333
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool WTW5100SQ
My whirlpool front load washer, only a year and a half in use, stops after filling and flashes the message F35. The trouble shooting manual does not give any explanation for F35. Any suggestions?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Jun 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
Water will not stop when level is reached but starts next cycle
If the water will stop when you turn the washer off then the problem is the water level switch. It's a switch connected to a hose which goes between the inner and outer tub. You can blow on it and the water should cut off. The filling water puts pressure on the switch with the air in the hose.
If the water doesn't stop when you cut the washer off then the water inlet valve is probably stuck open. The water supply hoses on the back connect to the valves.
Aug 22, 2009 | Washing Machines
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
Whirlpool ultimate care 2 water wont stop filling...over flowing everywhere.
Your level switch hose has come loose.first open the display panel to check in back of water level switch,and look for a hose that is not attached to the back of it.
Jun 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal De
