Question about V, Inc. Vizio P50HD Plasma Television
Pink Screen on Vizio 37 inch with HDMI Connection
Vizio 37 inch HDTV 1080p is connected by HDMI to Panasonic DVD recorder DMR-EZ48. The Vizio displays a pink screen occasionally when switching channels and between DVD recorder functions while the Vizio is on the HDMI input. There is a flash of pink with a light colored line in the middle while switching between channels even when the screen does not turn entirely pink. We have tried 4 different HDMI cables including a high speed Monster cable and two different Panasonic DMR-EZ48 recorders and the results are the same. This only happens with the HDMI connection. The Component connection and AV connections appear to not have this issue. The Vizio tech support person did not have an answer to this other than to try troubleshooting with the different cables and recorders.
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Posted on May 08, 2009
    New Friend:
  • 95 Answers
Main Digital HDMi board same not strong contact with ground. Take out the board clear pins w/ alcohol in of connector on the power supply board. Strong attach screw on the back plate HDMi port . If again same troubleshooting replace HDMI board
Posted on Mar 17, 2015
  • 34 Answers
Sounds like you may be getting some red pixelation. take a picture of the TV screen if you can capture and forward it to vizio. a lot of parts are warrantied for life so check with vizio support. could also be an issue with av cord from main board. hope this helps. J
Posted on Apr 08, 2009
I have a Panasonic DMR-EZ48 it will play for a short time then it freezes up and the only way I can un freeze it is to press and hold the power button for 30 sec then it will play but repeats the problem....
Is the media a commercial CD/DVD? Some copies made on another recorder or computer do not work well with devices other that one the copy was made from. In short, the angle of the read head may differ from the Panasonic DMR.
Jan 22, 2015 | Panasonic DMR-EZ48 Dvd/Vcr Combo Recorder...
On A dmr.ez48v on schedule a program on the speed on how mu ch time is left at the top of screen how do you change the speed
On the remote at the bottom next to record is RECMODE this changes the speed. You will have to select each recording you want to alter to change it I think.
Oct 20, 2014 | Panasonic DMR-EZ48 Dvd/Vcr Combo Recorder...
My VIZIO 1080P cannot connect thru HDMI cable To My Laptop
Just use the VGA/PC input instead. It requires an rs232 cable. It's HD and will automatically adjust the proper settings for the display.
Jun 08, 2014 | Vizio 47 120Hz 1080P Full HD LCD HDTV
Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
Mar 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
Hdmi connection
you need to connect to your tv via scart untill you have been into the setup and enabled hdmi
Dec 29, 2007 | Panasonic DMR-E80H DVD Recorder
V, Inc. Vizio P50HD Plasma Television Logo
2,654 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
