Question about Haier 5 cu. ft. / 142 liter Chest Freezer HCM050WA
Haier 5.0 cu. ft. HCM-050 not freezing
The freezer recently stopped freezing and in fact doesn't run at all. Prior to this happening there was very little frost built up on the interior or the freezer. My mechanical/electrical knowledge is somewhat limited but with the right information I have someone that could help. Thanks.
  • Webster Krough Mar 27, 2007
    Thanks, I will have someone in the industry check it out.
  • gman1 Nov 28, 2007
    Tapping the thermostat worked for me. Did you find a replacement?
I have the same freezer and recently it quit freezing. The thermostat is my problem. I checked the power outputs to turn on the compressor and it was not there until i tapped on the thermostat. I am currently trying to find another thermostat
Posted on Oct 02, 2007
  • 944 Answers
Unfortunately this sounds pretty surely like you need to get your freezer checked for leaks and re-gassed; control on refrigerants these days makes it very difficult and probably illegal to try and do this yourself, but any refrigeration repair guy should be able to do the job. slight worry is that the compressor could have seized, but this is not so often the case, sometimes a sharp whack can unjam a compressor, but get the fridge guy to look at it if he does the gas. Hope this helps :)
Posted on Mar 15, 2007
After placing my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA in a horizontal or tilted position it doesn't want to freeze
If you have run it in a tilted position, the oil has migrated from the compressor to the evaporator. You need a technician to flush the oil back to the compressor. Only run equipment like this on a flat level surface. and always allow to stand a few hours after moving before switching on.
May 01, 2014 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
I have deep freezer chest that does not freeze but when you plug it in you can hear it click on but will not get cold at all has been unplugged for a few years but stored in a dry building
If it doesn't get cold at all, then your compressor is not running. Which could be the start relay or start capacitor or even the compressor. The relay and capacitor are not that expensive and pretty easy to replace, but if it is the compressor then you might not want to put that much money into an older unit.
Aug 13, 2011 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Have a Haier 5.3 cu.ft. about 1.5 yrs. old. It freezes ok and cycles off ok, but it doesn't cycle back on unless I tap it near the control. If it doesn't call for more cooling it won't cycle on...
The thermostat is bad....
You will need to replace that t-stat..
That is not that hard to fix and you can easilybuy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
May 17, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
How long does it take to cool before putting food into it
i would let it run for about an hour then stock it. this is what we recommend after servicing
Jun 05, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
My freezer no longer freezes. were do start to
bin it. it is cheaper to replace than repair.other than the fuse that is.
Feb 03, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
My haier 5cu.ft. freezer stop freezing
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Nov 23, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050WA Logo
411 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
