Question about Dell Inspiron 1100 Notebook
Dell 1100 Will not power up
We put a Dell 1100 in storage and recently removed it for use. It will not power up. Any ideas?
  • ask_me520 Dec 17, 2008
    my dell inspiron 1100 has been sitting on the shelf for about a month now won't start up.lights blink and fan runs about 10 seconds then they stop. any ideas??
I would take out the memory and put it back in, just to make sure that it's properly seated. You might want to try the same with the hard drive.
Posted on Jan 09, 2009
I have a Dell Dimension 5150 which has recently been taken out of storage to use again. It hasn't been used for a minimum of 2 years. Before it being put away it worked fine. The motherboard light is...
This is one of 3 possible problems. Either your motherboard has gone bad, your power supply has gone bad, or the connections from the power supply to the motherboard are not secure.
Nov 20, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
I have dell inspiron 1100 laptop, when i turn it on fan goes on for about 15 sec,with no screen, power lights and battery lights either, i can hear sound from HDD and DVD rom, but after 25 sec everything...
Could be loose battery pack.
A bad memory chip would do this as well. Sounds like your not getting power.
Try this,
Unplug it, remove battery, wait couple minutes, press and hold the power button for 5 full long seconds, wait couple minutes more, then put battery back in securely, then plug in, turn back on.
Mar 07, 2010 | Dell Inspiron 1100 Notebook
Have a memory how must i put it in my pc
Here is a link to dell's website you will find the service manual. First remove the power cord and drain the power by pressing the button for 5 secounds. Second follow the steps for "Removing the computer cover" then after that "Removing and Installing Parts". Click here for service manual
Dec 01, 2009 | Dell Dimension 1100 PC Desktop
Dell Inspiron 1100 won't power up with battery & power pack both conected
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 09, 2009 | Dell Inspiron 1100 Notebook
Dell 1100 won't start up
Your RAM is failing. Please make sure the laptop is OFF, and put it up side down. You will see a panel ( i have an 1100 too ) in the middle of the laptop. Its about 2x4 inches. Unscrew the 1 screw. Remove one stick of RAM gently. Put the cover back on and turn the laptop on. If that works then throw away that ram stick you took out. If it doesn't work, take out the RAM stick that is still in there, and put the other one in by itself. If the problem still exists you've got some real issues, but i think thats the problem.
Apr 06, 2009 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 Monitor
HI, Follow these below steps
TAKE OUT BATTERY, REMOVE MAINS SUPPLY, HOLD POWER BUTTON DOWN FOR 30 SECS PUT POWER SUPPLY IN ONLY DO NOT PUT IN BATTERY TURN ON LAPTOP NOW PUT IN BATTERY
Jan 11, 2009 | Dell Inspiron 1100 Notebook
Won't boot up and battery and power lights flickering fast...
when you start it , do you have it running on the power supply or battery? Or, does it not matter?
Nov 04, 2007 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 Notebook Logo
55 people viewed this question
Alun Cox
