Question about GE Profile JGSP48 Gas Kitchen Range
GE Model JGBP40WEC4WW Gas Range oven glow coil would not lite.
Replaced glow coil. Glow coil lites and oven burner turns on. After 5 seconds, burner turns off and glow coil turns on again to lite oven burner. Over never reaches desired oven tempature. Glow coil and oven burner keep cycling on and burner tuns off too soon.
  • 470 Answers
The problem of your oven is the POWER SUPPLY,, a small microchip semi-conductor that provides power to your oven,, go to the technician  and tell about it bacause you had the defected power supply that cannot sustain the capacity of your oven, if you continously use it, it may have the chance to SHORT CIRCUIT, and it will additional problem to you,, go it with the technician and tell about it.
Posted on Dec 13, 2008
  • GE Master
  • 19,396 Answers
That means that there is a defective thermocouple.
  • Ginko
    Ginko Dec 13, 2008
    If the burner turns off after few seconds, that means that the thermocouple is defective, and does not keep the valve opened , even when the burner reaches the full operational themperature.
    Test and eventually replace the thermocouple, the job should be done by a technician , as the thermocouple must be tested at different temperatures.
    You find replacements and schematics by entering model number here.
    Give them a call if your model is not in the list.
  • 116 Answers
Have you checked the valve? it may be sticking reducing the gas flow, the oven runs out of gas and starts over.
My galaxy range model 790.60012604. The oven do not heat up . The element is lite up but the oven burner do not flame up which leaves a gas smell.
You need a new igniter, it may glow, but is probably not drawing the exact amperage required to open the gas valve decisively... You should also check burner tube and orifice for spider webs or other obstructions... Kenmore Range Stove Oven Igniter 316489402
Jul 05, 2016 | Galaxy Kitchen Ranges
Need to turn gas pilot on
Stove in ? has electronic pilot so there is nothing to turn on
top burners should have spark and oven has a glow
if the burners not lite do you here a clicking sound no clicking spark box is bad
oven not lite need glow
price of glow $40 price of spark box $60
Nov 02, 2014 | Hotpoint Kitchen Ranges
Lite oven pilot where is it
How old is this oven? I recently worked on my Magic Chief (mid 1980's model) and it did not have a pilot. It has more of a "glow plug" type ignition system, and I was able to replace the glow plug. This was about a $50 generic part, but it works fine now.
Gary B.
Feb 08, 2011 | GE 30" Freestanding Gas Range - White
Our glow bar lights up when gas oven is turned on, then the gas comes out, but it takes a long time to lite the gas resulting in an explosion inside the oven. Or with too much gas filling up the kitchen....
Typically the issue here is a weak glow bar (hot surface ignitor). When they weaken they open the gas valve slowly and it takes a bit for the ignitor to light up the oven burner.
It is a safe bet that you need to replace it.
Apr 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
GE Gas Range/oven Model JGBS16 The glow coil in the oven works intermittently. When it doesn't come on we find that turning the control knob on and off several time will help or if we start one of the...
could be a bad thermostat but it sounds most likely like a loose wire connection somewhere. if the coil comes on and doesnt quite glow as bright as it should, the glow coil needs replacing.
Oct 10, 2009 | GE JGBS17 Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
OVEN WILL NOT (GAS) LITE
With the assumption you have a gas range with electric ignition and is fully powered (plugged in); the possible problem may be the "Electric ignitor/Glow bar".
When turning on the oven, do you see a redish (good) or yellowish (not good; replace) glow emitting from the very bottom or the oven/broil area?
There are typically 2 types of electric glow bar ignitors; Round and Square. Ignitors are actually fairly easy to replace, removing 2 mounting screws and cutting/splicing 2 seperate wires together. Is your ignitor "round" (circular - like size of finger ) or "square" (rectangular - like snickers candy bar)
If your ignitor is not coming on at all; this can be a couple things;
Defective Ignitor - Gone completely Bad - Out (Assuming your have full power 110v to ignitor)
Defective Gas Valve - Assist in passing 110V to Ignitor
Defective Control Board / Thermostat: Assist in passing 110V to Ignitor
FYI - As a safety measure, the ignitor needs to "come on and appear solid red" to properly pass power to gas valve; thus opening and allowing gas to pass through the burners and combust.
Jan 27, 2009 | Magic Chef 31203 Gas Kitchen Range
Ligthing the oven glow bar
you need to replace the oven glow bar take out the oven racks in the bottom of the range you will see two screws remove them remove the bottom oven pan under that is the flame spreader shield under that under it you will se the ignighter at the back of the burner bar just follow the instruct sheet with the ignighter to install and reverse just because the old bar glow-es don't mean its good just replace it
Jul 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Feb 01, 2008 | Tappan TGF363 Gas Kitchen Range
GE Profile JGSP48 Gas Kitchen Range Logo
171 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
