Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Relay won't stop clicking
I was having problems with the dispenser in the door. I'd try to get water or ice and all I'd get is a dim light. I got around the problem a couple of times by taking some ice out of the packed full tray. Now the problem has worsened into a relay that won't stop clicking unless I turn the freezer control to zero. Other things I noticed along with the relay is that the compressor pulses slightly in time with the relay. The fan also nudges forward 1mm then back. The damper between the compartments also seems like it is trying to close even though it is closed already. I think the damper actually stopped doing that after a while. The unit is 1.5 years old.
  • 1 more comment
  • Matthew Random Mar 11, 2007
    Board...
    J7-9 (orange) to harness J11 (gray) is 121.7-121.9 V.
    J7-9 (orange) to harness J8 (blk) is 2-9V (fluctuates).
    J7-9 (orange) to harness (blue) is 0V.
    Fan...
    white to red 1.5KOhms
    white to yellow no reading
    I only saw one fan. Unplugging the fan didn't stop the relay clicking. The click frequency is 1 per second. The clicking is coming from the relay just above the 3-wire harness at the bottom of the board.
  • Matthew Random Mar 12, 2007
    The gray wire I mentioned is actually brown and it the terminal labeled line so I'm seeing 121.7 to 121.9V between J7-9 and the line terminal.
  • Matthew Random Mar 13, 2007
    Turns out the problem was the board. The unit is working fine with a new board.
    President:
  • 878 Answers
Matt, sounds like you have a main board problem here. The main board is on the back side of the refrigerator. If you are handy with a meter you can do some checks. Is the clicking relay coming from the main board? If it is, than it's more than likely your problem. First check the voltage from connector J7-9 (orange wire) to blue harness to the left, terminal marked line. This should have a steady 120V, no fluctuation. If you don't have this, replace the board. You want to make sure that the condensor fan motor and evap fan motor are not shorted. A shorted motor will take out the board. At the fan motors harness, with the power off, if you read less than 1K ohms between white to red or white to yellow it's bad. This is for both the evap and condensor fan motor. The part number for your board is. WR55X10543...Catriver..post back.
Posted on Mar 11, 2007
I have a gsl25jf side by side. Ice will not dispense - ice continuess to be made. Water will dispense - after you try to have ice dispense from the door there seems to be a clicking sound the lights dim on...
PULL THE ICE DESPENCER OUT AND RUN HOT WATER OVER IT AND START FRESH . IT MIGHT JUST HAVE A ICE JAM, I HAVE SEEN THIS BEFORE, THE ICE BUILDS UP IN LAYERS AND WONT ALLOW THE TREY TO SIT IN SNUG TO THE MOTOR .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
108 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
