Question about Breville Conical Burr Coffee Grinder - Stainless-Steel
I cleaned my Breville grinder and tried to put it back together but the bean container will not fit back in. Please help.
This might be it. On the bean container there is a white dart and the word 'align'. The same dart and word appear on the top of the grinder. Align the two darts and the bean container should drop right in.
Posted on Dec 19, 2008
How do I dismatle the grinder on my Krups espresseria automatic
I suspect that as you have only managed to remove 2 screws from the beans container that this is going to be quite a task for you but here goes.
1) Remove the button from grinder adjustment by pulling or levering upwards
2) Lift beans container off
3) Remove front trim panel (square frame like a picture frame at front) Done by removing drip dray and thumping frame upwards with heel of your hand.
4) Undo 2 outer screws at top front of top housing
5) Undo screw in middle at back under where beans container was
6) Lift off top housing, you may need to rock & flex it a bit to release rear clips
7) Put knob back in & turn grinder adjustment fully right (clockwise)
8) You now need to mark that part of the grinder top that goes between knob and grinder so that you will be able to put it on exactly as it is now. Then remove that part from the top of the grinder
9) Now you can turn the top of the grinder anti clockwise further than the adjustment knob was moving it.
10) Once you have turned it as far as it will go you will be able to lift (with wriggling) the top part of the grinder out.
11) Cleaning out will be done with a small screwdriver and vacuum cleaner with nosey parker attachment fitted.
Dec 29, 2014 | Krups Coffee Makers & Espresso Machines
Hi my breville barista express does not grind the beans, and the "single/double" light is blinking, what is the problem?
My wife tried to make my coffee and long story short, she removed the lid to "move the beans around"..The grinder stopped working and the filter size lights began flashing intermittently. After taking the whole thing apart, the only REAL problem is that the lock mechanism inside the hopper came unlocked. So put your machine back together and "lock" the hopper. The lights will stop flashing...lets hope
Sep 26, 2013 | Breville Die Cast 800ESXL Espresso Machine
I have a Breville BES860XL and the grinder is not working. If i overide the interlock, It will spin, but does not have enough power to grind beans
It seems there's a fault in the grinder gearing in this particular model.There's no solution but to take it to Breville repair...
I have the same problem and so does a friend of mine. The grinder will spin without beans in the hopper but as soon as beans are introduced the grinder makes a loud noise. Like the gears are slipping and there's not enough power to grind.
Jun 10, 2011 | Breville BES860XL
Grinder doesnt grind beans although the motor works and the burr spins. I have cleaned it per the instructions and reassembled . Everything seems to fit together properly, but the beans don't seem to be...
I would suspect a log in the outlet shute where it goes into the grinds hopper. Clean it out and then turn the hopper to the coarsest setting to clean it out all together. Coarse grinds are a very good cleaner.
Oct 03, 2010 | Solis Maestro Electric Burr Grinder
Severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
May 12, 2009 | Breville Conical Burr Coffee Grinder -...
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Water does not blend with coffee
When you mount the grinder back, do you turn it so the red mark fit together?
Try to check the brewing unit, on the top off the brewing unit you will see a little pin. Take it out and make sure this is clean and put it back again.
/Mirran
Sep 02, 2008 | Saeco Incanto Classic Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Breville Conical Burr Coffee Grinder - Stainless-Steel Logo
869 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
