Question about Westinghouse SK-19H210S Television
Dead set 19" lcd model sk-19h210s fuse shows ok trying to see if power supply is available part number on it is 2995304400
  • 10 more comments
  • forest_tv Feb 07, 2009
    set working fine now
    thank you
  • qwikfix31 Feb 10, 2009
    I have the same issue! On a 1-10 scale, how easy/hard is it to solder in that part? Thanks in advance for the help!
  • tvforfreeguy Feb 10, 2009
    power cord is showing electricity running through it but tv won't turn on. Help!
  • bobzi Feb 28, 2009
    Mine won't turn on, but I can't find where the fuse would be.  Thanks, Bob
  • Anonymous Feb 28, 2009
    19h210s over a year old, fuse ok, changed 2200 cap but no change, other suggestions appreciated
  • bbrown21 Mar 01, 2009
    our sk-19H210S has no power. what did you do about yours?
  • cgilliam Mar 01, 2009
    No power on mine started today and was purchased a little over a year ago...anyone know how to take it apart to check the fuse and power supply.
  • Anonymous Mar 13, 2009
    power supply went out after 16 months, replacing the cap fixed it thanks
  • prvaughn Mar 30, 2009
    I have a Westinghouse LCD TV, model SK-19H210S. It won’t power on. It’s almost two years old. I’ve tried plugging it into outlets in a different room. It still won’t power on. Before it stopped working, for a couple weeks, it was slow to power on. The time to power on steadily increased during this two-week period to about 20 minutes. Now it won’t come on at all. Any thoughts on how to fix this?
  • Anonymous Apr 12, 2009
    set was flakey, then would not turn on at all.
    replacing the 2200 uF capacitor on power supply fixed it.
  • Anonymous Apr 16, 2009
    Won't turn on. 14 months old.
  • tbruns1 May 24, 2009
    I replace the 2200 cap and now nothing I can hear a ticking noise but that is it
Im not sure if this will fix your tv, but mine was powering off intermittently. I found a defective
2200uf Capacitor on the power supply board. Take a look at the top of the capacitor cans,
mine was popped up an looked damaged.
Posted on Jan 27, 2009
  • pjcjr Feb 01, 2009
    I just replaced the 2200uf Capacitor on the power supply board and the TV is fixed.
    Good Luck!
Found two web site that sell one is and the other is be prepared to pay over $100.00
Posted on May 24, 2009
I have just started the repair or my westinghouse SK-19H210S, upon opening the unit there were 2 blown caps on the delta 2995304400 power supply board, capacitor number CE105 and CE103 though to be safe I would also replace CE104 and CE102 as they are also capxon capacitors which are prone to failure I have found the same defective capxons in ctx and viewsonics I would recommend rubycon caps.
Posted on Jul 15, 2010
I had the same problem and then replaced the cap. Now it works which is great but I have no ability to change channel, volume, etc. what did I do wrong?
Posted on May 22, 2009
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
Oct 16, 2015 | Westinghouse Televison & Video
I have a Westinghouse 19" LCD Model @ 19H2105. Was working fine this morning. Just tried to turn it on and have black screen and no audio. The blue indicator light comes on, but no easily. Have to keep...
Look for bad caps as shown here:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Capacitors kit: he can make you a set of caps for you
Sep 16, 2010 | Westinghouse SK-19H210S Television
My westinghouse 19H210S quit working 1 year 3
I also just changed the bulging capacitor and also it still does not work. Even though it was bulged when I tested it after changing it the capacitor tested normal. Not much help but clearly the 2200 capacitor is not the only problem.
Apr 15, 2010 | Westinghouse SK-19H210S Television
Repalaced bad capaitor(bulge on top) Now powers up. snowy with sound and picture goes blank. With nothing on screen. Tried to use remote but nothing shows up on screen. Note the snow is from not being...
When the filter caps went bad, the power supply output will be AC and feeding the circuits which can damaged the parts on the board. Check to see if you have the 12 or 18v feeding the back light invereter board. There are surface mounted fuses on the inverter board also. Send me good pictures of the whole back where all the boards are and close up picture of the inverter board, may be I walk you through.
Dec 10, 2009 | Westinghouse SK-19H210S Television
Westinghouse Model SK-19H210S Won't Turn on just ticks.
Hello, it sounds like you need to replace your power board, you can find price and availability for this power board by emailing
Nov 06, 2009 | Westinghouse SK-19H210S Television
Went Dead After 18 Months! Westinghous Model SK-19H210S
your tv has a bad electrolytic cap rather easy to replace it only has 2 legs to unsolder.
location number CE105 its a round can thats swollen at the top.value is 2200 MF at 10 volt replace it with 2200 MF at 16 volt
Sep 19, 2009 | Westinghouse SK-19H210S Television
Westingnouse SK 19H210S
Check the postings on replacing the 2200MFD capacitor (CE105) on the power supply board with one rated at 16V. Make sure to get the polarity correct when you replace the capacitor. Worked on the one I fixed for a neighbor.
Sep 09, 2009 | Westinghouse SK-19H210S Television
Sk-19h210s turn on off
replaced the 2200uf 10v capacitor on the power supply board. cost 90 cents from Digi-Key on the internet and a couple of bucks for shipping. NOW MINE WORKS FINE
Jul 07, 2009 | Westinghouse SK-19H210S Television
Westinghouse sk19h210s won't power on. service
I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again.
Just be careful and take notes when you're digging into it. And mark exactly where the card cage is before taking it loose.
Mar 05, 2009 | Westinghouse SK-19H210S Television
Televison & Video Logo
1,340 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
