SanDisk Sansa m240  MP3 Player
Problem for SanDisk Sansa m240 (1 GB) MP3 Player
How do i put a playlist on a sansa m240
By loveme on Mar 11, 2007
i have tried almost everything people have said on how to put a playlist on my mp3.all people have told me is how to do the favorites.but, i want to know how to put the playlist on under music/playlist and no one can tell me.So please help!!I need it
Same Problem
Apr 23, 2009
-   hdhdh-   Guest
Solution #1
posted on Mar 22, 2008
Somewhat Helpful)
dmil
Rank: Apprentice
Rating: 87%, 6 votes
Creating Playlists on the Sansa M240
The Sansa M240 is a decent device, but if you are like many, you have not been able to create playlists. The instructions with the player and the maker’s website offer little help. Here a solution that I found on-line with some additional detail. The step by step instructions for even those with little computer savvy.
1. power up your M240 player without connecting to your computer. Scroll thru the menu to the “settings” menu. Select “USB”, deselect “auto detect” then select “MSC”. (I don’t know if this step is critical, but I picked up this suggestion from another site)
2. Power down the MP240 and using the cable supplied with your player, connect to the USB port of your computer. The display will show “MSC” when connected.
3. If you have not already done so, download the songs you want to include on your playlist from your computer to the M240. Any number of media player software packages will allow you to copy or burn your songs to a “portable media device” for this step.
4. After your songs are downloaded, on your computer, go to “My Computer” and open the "Sansa M240" icon. On the explorer task bar, select “view”> “details”. You should see several standard folders and all your songs. (Note I have used this for both .wma and .mp3 formats and have intermixed them in the playlist)
5. On your computer, open a new Notepad document and save it to your desktop.
Name it whatever you like, but it has to have “.m3u” as a file extension when you save it.
For example I named mine…. playlist1.m3u, playlist2.m3u, playlist3.m3u.
6. Next, in this newly saved notepad document, type this exactly on the very first line < #EXTM3U > without the brackets.
7. Now, find your first song in the open M240 folder, place your cursor on it, right click and select "rename". When the song title is highlighted hit control + C or "Copy" the entire title, being careful not to change anything. Now place your cursor immediately after the #EXTM3U text, hit return and paste the title of your first song directly below it with NO line space in between.
8. Repeat the steps to copy the title of your next song from the M240 folder. When copied, place your cursor immediately after the previous song title copied in the step above. Hit return Twice to create a single line space after the song title and paste in the next song title at the beginning of the line. Repeat this process til you have built your playlist.
8. After you’ve entered your last song title, it should look something like this. (Either .mp3 or .wma extensions can be used)
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Now, within your notepad playlist document, click File/Save (noting where it was saved) and close the file. Now, find that same original playlist on your computer. Highlight it and copy / paste it onto your M240. I copied mine into a folder called “playlist” on the M240. Then I repeated the process for other playlists, giving each a unique name.
After allowing sufficient time for the file to copy, use the icon in the lower taskbar of your computer to “safely disconnect hardware” to unplug your player. Disconnect the USB cord, power up and your ready to enjoy your playlists.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Mar 29, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the 2gb M250...I think they're probably similar. What I did (which this only happens 25% of the time or so) is synced through Windows Media Player. I put entire playlists into the sync bar and then synced. (not individual songs). some of the time I do this it will add the playlist to my player...other times it doesn't, and I have to keep repeating it several times until it works. Very buggy....
Popular Solutions for SanDisk Sansa m240 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa m240 MP3 Player
Do you recommend SanDisk Sansa m240 (1 GB) MP3 Player?
Answer
Answer
ipod is not ipod is not playing ? what may be the problem
Answer
Answer
i have sansa m240 this consists 930mb data ,which is i can able hear but when it is inserted to my... (More)
Answer
sansa clip mp3 not recognized by my computer just quit charging the device-does not show up on the... (More)
Answer
screen broken, just want to play music in random order. I can't see anything on screen. Is there a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
