Question about NetGear WGT624 Wireless Router
Can not get netgear to go on line
Lights went out then when they came on could not get on line tryed unpluging setting ping and resetting boxes can only use verizon modem to get on line but I also use net gear router. Tryied every thing to get on line but nothing works
  • 20 Answers
Give a try by resetting your router n reconfigure it,that might fix your problem
Posted on Dec 16, 2008
Authentication failed
A Netgear wireless router attaches multiple devices to your Internet connection, either by ethernet cable or wirelessly.
If you can't connect to the Internet, the problem can be anywhere along the chain of devices and technologies that connect your computer to the Internet.
Knowing how to troubleshoot your Netgear or other wireless router is an essential part of determining where the problem is and fixing it.
Click your "Start" button, and choose "Run."
Type "cmd" in the text box (without quotation marks), and click "OK."
A command prompt will open. Type the following: ipconfig /all. Press your "Enter" key.
A list of numbers and other networking configuration information will display.
Find your network adapter in this list of headers.
If you use your computer wirelessly in many different places, you may have to scroll through a lot of different options to find your adapter.
If you connect to the Internet using a cable, look for a header that begins with "Ethernet adapter Local Area Connection."
If you connect wirelessly, look for a header that begins with "Ethernet adapter Wireless Connection."
You will usually only see an IP address displayed under one header in either category.
Record your IP address and default gateway on a piece of paper or in a text file.
If your IP address is or begins with 169.254, unplug your Netgear router from its power source.
Unplug your cable or DSL modem as well.
Be sure to unplug both devices; turning them off with a power switch may not have the same effect.
Wait 20 seconds before plugging the modem in again.
Wait for the lights on the modem to light up.
Plug in your Netgear wireless router again.
Wait for two minutes. Use "ipconfig /all" again.
You should have a different IP address now.
Ping your default gateway.
At the command prompt, type "ping" (substituting your default gateway address for
You should receive four responses, all of which will begin with either "Reply from" or "Request timed out."
If you receive "Request timed out," unplug your Netgear wireless router from the power source for 20 seconds, and plug it in again.
Wait two minutes before using "ping" again.
If you receive "Reply from" responses, check to see if your Internet connection is working again.
Open a Web browser. In the address bar, type "" (substituting your default gateway address for
Press "Enter." If you have password-protected your Netgear router, you will be prompted for a username and password.
The default username for a Netgear router is "admin."
When you have successfully entered the username and password, your Web browser will show you the configuration page for your Netgear wireless router.
If your Web browser never loads a Web page or prompts for a username and password, you're not communicating with your Netgear router.
Double-check the address you typed into your address bar.
If you've typed it correctly and your connection is wireless, either your wireless card has a problem or your Netgear router is not correctly sending a wireless signal.
Make sure your wireless card is enabled (using Windows' built-in Network Connections applet or the third-party software that came with your wireless card).
Make sure your connection settings (SSID, security type, and key or passphrase) are correct for your network.
Look at the lights on your Netgear wireless router.
The wireless indicator light should be green.
If it's orange or not on at all, your router is not sending a wireless signal.
Make sure all the settings on your Netgear configuration page are correct.
Most Internet providers use a dynamic IP address and DNS server addresses.
Some Internet providers require a login, and some do not.
To be sure, refer to the configuration information your Internet provider gave you when your Internet access was installed, or call your Internet provider's technical support number.
Click on "Wireless Settings" on the navigation bar on the left-hand side of the page.
If you were not able to reach the configuration page wirelessly and had to connect to your Netgear router with an ethernet cable, make sure these settings are still as you defined them when setting up your network.
If not, either change the settings to suit you, or change the configuration of your wireless card to match these settings.
Be sure to click the "Apply" button if you make any changes.
Click "Router Status" on the navigation bar on the left-hand side of the page.
Under "Internet Port," check your IP address.
If the address begins with 169.254, you're not communicating with your cable or DSL modem. Unplug your cable or DSL modem from its power source for 20 seconds, and plug it back in. Wait two minutes, and refresh this page.
If your IP address still begins with 169.254, there is a problem either with the cable connecting your Netgear wireless router to your cable or DSL modem, or with the modem itself.
If your IP address is, there is a problem with your Internet connection, and you should call your Internet provider's technical support.
Record all your configuration information before trying to reset your Netgear wireless router to the factory defaults.
Resetting may fix your problem, but it will wipe out all your configuration information, and you will have to reconfigure your Netgear router from scratch afterward.
To reset most Netgear routers, use the tip of a pen or an unbent paperclip to press and hold the reset button on the back of the router until the test light blinks.
Release the button, and wait two or three minutes.
Connect to the router's configuration page in a Web browser.
Log in with the default username and password, and configure your router.
You may have to connect to the router with an ethernet cable to perform this initial configuration.
Jul 12, 2013 | NetGear Computers & Internet
My modem is hooked up to a netgear wireless router, my internet was working before but isn,t now. How can I get it to work again? It has been reset, and unplugged.
unplug the modem and the router wait 2 mins. Plug the modem in first and wait till all of the lights are solid on the modem then plug the router in. If you reset the router to the factory state chances are you are going to have to set up the routers wizard again the routers ip is usually the default login is admin for the user and password for the password
Mar 07, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
Laptop stopped picking up Internet. Went in other room and the desktop couldn't find internet either. Logged off both and checked the Netgear box and the lights were all yellow, not green. There isn't...
Unfortunatly, if it won't even power up anymore, there no way to even diagnose what the problem might have been. sorry to say, but i think it may be time for a new router.
Mar 04, 2011 | NetGear RangeMax NEXT WNR834B Wireless...
I am trying to helpy parents. They have a netgear wireless router. We know the ID but my mother made an 8-character long password that no one can remember. The router was originally set up on a computer...
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Try using a pen or paper clip to press the reset button on the back of the device. Keep the button pressed until the lights in the front of the Netgear router start flashing. The router will reboot after resetting the configurations.
Open a internet explorer browser window and enter
the Netgear router configuration console will open and will prompt you to enter username and password
Enter the default username and password. Now that settings have been reset, you can use the Netgear global default username and password listed below:
username: admin
password: 1234 or password
Unplug the router's power cable if these passwords do not work. If you are still unable to login, the router may not have been reset. While the router is unplugged, hold the reset button for 20 seconds before plugging in the power cord. Repeat Steps 2 and 3 to gain access to the router, using the new admin username and password
Dec 26, 2010 | Computers & Internet
My wireless laptop won't connect to network printer using netgear router . When hard wired over LAN, printer works. Cannot ping when laptop is wireless. Other computers work fine. HELP~
  • laptop has to be connected first to SSID
  • then ping is possible
  • or else reset the wireless settings: change SSID name, channel 6, and no password first
Jul 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
Need to reset netgear router wpn824v2
Don't tell me you tried to upload the firmware from a wireless connection.
It's probably bricked. You could act stupid and send it back to Netgear, claiming it just died...(it did right?) and in the meanwhile, Staples is selling 624's for $40 this week.
Jul 05, 2009 | NetGear RangeMax WPN824 Wireless Router
Can't access configuration for Wgr614 v5 Netgear Wireless router
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Dec 22, 2008 | NetGear WGR614 Wireless Router
hi ,
i went through the problem that u r telling me nut i think that the router has gone bad so u can call customer care of ur router and they will replace ur router .....
Oct 25, 2008 | NetGear DG834G Router
Netgear wireless connection
Check the wireless IP address on the XP computer. try to ping default gateway and see whether its giving succesfull reply, after that do ping and check successfull pinging. if it pings successfully the yahoo website , then you should go online.
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NEtgear RP614 cannot connect after a electricity shortage in our home :(
How is it not working? You get limited or no connectivity or it isn't functioning at all. Firstly, let's do a power cycle. Push the reset button for 5 seconds, unplug for 45 seconds, and reset 5 seconds, and unplug for 45 seconds. If that doesn't work try a hard reset. Alright, it's time to do a hard reset, this will rest all your passwords, Take a Pen or a pin, push the pin the the reset hole for 45 seconds, Uplug the modem for 1 minute, reset hole for 30 seconds, unplug for 30 seconds, and it should be hard resetted also power cycle.
Aug 25, 2007 | NetGear RP614 Router
NetGear WGT624 Wireless Router Logo
52 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
