My newer Sylvania LC195SL8 suddenly has no sound on 4 channels. I've re-booted, disconnected the dvd player, re-set the channel scanner multiple times. Two other televisions on the same Comcast cable service are working fine. Do I need to make use of the warranty or is there something else I can try?
  • shannaz Dec 16, 2008
    My Comcast cable support person told me to locate the SAP button on the matching remote. It was indicated by a musical note & I hadn't attempted any repair with it. Once I pressed that button, a screen idicator showed 'SAP'. Choices were SAP, Main and Mono. When I choose 'Main', the sound was restored to all channels. There was nothing wrong with the set.
  • 116 Answers
I would make use of the warrantee while you have it, that way you wont have to pay a nickel.
Posted on Dec 13, 2008
Connecting memorex mdl mlt 1921(a) tv to sylvania mdl dv220sl8a vcr
Are there video settings as well?. If so, try one of those. That should work.
Dec 07, 2011 | Televison & Video
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
Im looking for codes for a sylvania tv
The codes to try for Sylvania TVs are 0054 0030 0171.
The manual and codes are available from the One For All support site: http://www.oneforall-na.com/remote.php?type=URC%203021 . The link for codes is at the bottom right of the page.
However, most remotes are limited to codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, then you may need to get a newer remote.
I hope this helps.
Feb 25, 2011 | One For All URC-3021 Remote Control
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
What channel does this TV need to be set on for a vcr/dvd player
If the vcr/dvd player is plugged in to your TV using composite or component cables (Google images them for a view) then you would select an "INPUT" not a channel. Old TV-VCR tv hookups required a channel select of usually channel 3 or 4 but newer equipment uses an INPUT selection usually found on the remote. Look at the back of the tv where you plugged in the dvd and it should be labeled what input it will be.
Oct 19, 2009 | Sylvania 6637LCT 37 in. LCD Television
I have a 19 sylvania tv that I want to connet toToshiba DVD playe
If the TV doesn't have AV input jacks, you'll need an RF converter so you can watch the DVD player on channel 3 or 4. You can find them at Radio Shack, Wal-Mart, Home Depot and most places that sell TVs for around $15. Connect the audio and video from the DVD player to the inputs on the converter, and the converter's output to the TV antenna jack. Set the TV to whichever channel the converter is set for (3 or 4, with a switch on the converter so you can choose) and you'll be in business.
Sep 14, 2009 | Sylvania Televison & Video
Sylvania vcr-dvd defaults to channel 3 need to change it to channel 4
try looking in the setup menu by pressing the menu button on the remote and navigate through the menu to find the setup options hopefully you should beable to change the defualt channel setting
hope this helps,ben
Aug 10, 2009 | Sylvania DVC840G DVD Player/VCR
I have sylvania t.v. that has only one white and one yellow plug in on the back I can not get any picture or sound from the dvd player.
That set has lived too long, methinks. The yellow one is customarily composite video (no sound) and the white one is (again 'normally') the left channel of a stereo input which is something you don't have, otherwise there should be a red-marked jack for the right channel. In your case, the white jack may be a monaural input for sound.
Jun 14, 2009 | Mintek DVD-1600 DVD Player
Center Channel Audio
There are probably several sound settings on the receiver :
Dolby surround , stereo, theater, SACD etc.
Try another setting other than the one you have
Dec 16, 2007 | Yamaha RX-V661 Receiver
Dvd burner
Can you try just running a/v cable from your tv output to the inputs on the ilo, then whatever you watch on your tv you can record on your dvd burner. My new SDTV doesnt have audio out except Coax so this won't work for me on that tv. Why doesnt the newer tv's have audio AND video outputs???
Oct 30, 2007 | iLO DVD Recorder DVDR05
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
