Question about Whirlpool Duet GHW9150P Front Load Washer
Washer displays DL error
I press the start button and it just clicks - sometimes the washer will start and then mid stream stop and give this DL code and then a F. I have tried unplugging it pressed the cancel cycle button, turned the fuse box to the washer off and turned it back on to see if it would some how it would reset itself. Please help????
  • 3 more comments
  • Anonymous Mar 16, 2008
    I have same problem . Door does not lock and just hear clicking noise then code F then DL
    My washing machine also kept flashing dl, so I had a repair man come and he fixed the door latch. But, less than two months later, it started doing it again and flashing f 11. Now it is constant, but if it does sit for over 48 hours,with the wet clothes inside, it somehow manages to start again, and I am good for two loads. A viscous cycle. This should not happen on such an expensive machine that is less than five years old or even ten for that matter.
  • Anonymous Aug 04, 2008
    How did yo ufinally get the door open? Mine is doing the same thing. I have hit cancel and unplugged it and it still is locked with of course clothes in it waiting to be washed.
  • Anonymous Mar 17, 2014
    washer won't start cycle..dl code comes up
  • Anonymous Mar 20, 2014
    I raised the lid after canceling and the washer would not restart, unplugged for 20 sec and now it will not power up?
  • 5,911 Answers
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Posted on Apr 29, 2007
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
Clicking and F dl error
Error code stands for door lock. May need a new door lock.
Oct 23, 2009 | Kenmore HE3T Washer
Kenmore HE3t font load has fault code DL and will not start cycle or stops in mid cycle with this code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 02, 2009 | Kenmore HE3T Washer
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
Washer DL error
F/DL is indeed a door lock error. I had this on my machine, did a lot of research and getting some idea of how it works. The code is generated when the CCU can't lock the door. Possible causes are door latch mechanism, connecting wiring, or the CCU. I could hear clicking from the CCU on my machine which indicated to me the CCU was trying to lock the door. It tries 6 times before setting the F/DL code. I tested the latch and wiring from the CCU - OK. The clicking I heard had to be relay(s) so I figured the problem was relay contact failure. I removed the CCU board, determined which relays were suspect (there are two for lock & unlock). I changed them both and saved myself spending $300 CA on a new CCU. The relays cost just over $2 each. I found replacement relays @ Electro Sonic (www.e-sonic.com; minimum $25 order plus shipping $7.50). Relay made by OMRON part # G5LE-14-DC12 replacment for original G5LE-1-VD 12VDC. I'm not impressed to have to change a $300 CCU because of a $2 relay failure. For me this was worth the try as I have some experience working with circuit boards. The relays would be a quick repair for anyone with similar experience. Hope this helps someone.
Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
820 people viewed this question
Dan Webster
Dan Webster
Sal De
