Question about Apple iPhone 3G
Syncing outlook and IPhone
How do i sync outlook and iPhone
  • 470 Answers
1. Run all relevant software updates.
Boot Microsoft Outlook and run Help | Check for Updates. Also make sure that no new
Vista updates are available before continuing to step 2. If there are new updates waiting,
install them first.
2. Set up your mail account.
For this howto, I tested a Gmail account set to IMAP, which I then synchronized with Outlook 2003.
 (To convert your Gmail account to IMAP, head to Settings | Forwarding and POP/IMAP |IMAP Access and click Enable IMAP.) It doesn’t matter what kind of e-mail account you use: The iPhone 3G will sync with both POP and IMAP accounts.
3. Delete your iPhone 3G’s current mail configuration.
If you’ve already tried this before without success, delete what’s currently in the iPhone 3G and start over.
 From the main menu, go to Settings | Mail, Contacts, Calendars | Accounts.For any accounts listed,
click each and then click the big red Delete button on the next page. The iPhone 3G can’t sync over the air with an Exchange server and also sync to a desktop Outlook setup;
try it and you’ll see the following error message: “Your contacts are being pushed to your iPhone over the air from Microsoft Exchange” instead of the Info tab you need in one of the later steps.
4. Connect your iPhone 3G to your PC.
When you do this, iTunes should fire up automatically on your PC. iTunes may prompt you to update your iPhone 3G to the latest version
 (2.0.2, at the time of this writing) if it’s not current. Note: Be sure to also update iTunes to version 7.7.1 or later. Some users have reported online that the 7.7.1 update fixes issues related to Outlook synchronization
5. Set Outlook contacts to synchronize.
In iTunes, click on the name of your iPhone 3G underneath Devices in the left panel. Then across the top, click the second Info tab, and scroll down to the Contacts section. Check the box that says Sync contacts with Outlook, and click All contacts if it’s not already selected.
6. Set calendars and e-mail messages to synchronize as well.
Repeat the process for the calendar and e-mail sections, which are located just below the Contacts section.
7. Apply the changes.
When you’re done, click Apply. The iPhone 3G should begin synchronizing on its own. You shouldn’t even have to disconnect the iPhone 3G to see if it worked. Click the iPhone’s button, slide the lock to Unlock, and then check the Calendar and Contacts sections. Your Outlook data should now be on the iPhone.
From here on out, each time you synchronize your iPhone 3G, it should automatically pull mail, contacts, and calendar updates from Microsoft Outlook, and vice versa.
If you’re still having trouble, leave your current e-mail account aside and add a new one in Outlook. Try creating a test Gmail account, which allows free POP and IMAP sync. Set up that test account with Outlook and again with the iPhone 3G using the steps above. This way you can isolate the problem and see if it’s something related to your current account’s PST file in Outlook, or a problem somewhere further down the chain..
Posted on Dec 13, 2008
  • 275 Answers
Sync Your iPhone With Your Outlook Calendar Using iTunes Step1syncing outlook and IPhone - 15700_65x95_aspect.jpg Open iTunes and check to make sure that you have the most recent version. Do this by clicking on "Help" and then click on "Check for Updates." Step2Use the cable that comes with your iPhone to connect it directly to your computer. This will automatically launch iTunes. Select "iPhone" from the iTunes source list. Click on the "Info" tab in iTunes. Step3Click on the "Sync Outlook calendars" option. Click on "Apply" in the lower right-hand corner of your screen. Your computer will now sync with your iPhone based on your settings.
  • 116 Answers
I am researching this for you here is what I got so far click here
  • 492 Answers
    Master:
  • 479 Answers
  • Apple Master
  • 19,396 Answers
Follow instructions below:
How to Sync an iPhone with your Outlook
  • Apple Master
  • 13,433 Answers
serra_baby
  • 144 Answers
SOURCE: Sync iphone calendar with outlook 2003
hello!
try the ff:
Reset Sync History
- Open iTunes
- On the Edit menu, click Preferences.
- Click the Syncing tab.
- Click the Reset Sync History button.
disable third-party add-ins
- Open Outlook 2003
- From the Tools menu, choose Options.
- Click the Other tab.
- Click the Advanced Options button.
- Click the COM Add-Ins button.
- Determine whether any third-party (non-Apple) add-ins are present in this list. The add-in "iTunes Outlook add-in" is made by Apple and can be left alone.
- Deselect the checkbox for each third-party add-in in this list.
- Click OK.
Reinstall the iTunes software
Attempt to sync content in a new Windows user
- From the Start menu, choose Control Panel.
- Open User Accounts.
- Select Create a new account and follow the instructions to complete the account setup process.
Note: Make sure you only use standard ASCII characters for the new user name.
- Once the new account is created, choose Log Off from the Start menu.
- Log into the newly created user account.
Once you are logged into the new user account, create a few test contacts and/or calendar events in your compatible application of choice and attempt to sync that data to your iPhone.
Posted on May 08, 2008
SOURCE: iPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
With the Iphone 2.0 or the 3G you can fix the time zones by:
1. Go to Settings
2. Go to Mail, Contacts, Calendars
3. Scroll down to Claendar- Time Zone Support
4. Change the time zone
Posted on Jul 26, 2008
SOURCE: Sync Outlook 2000
utube.gifygkhg
Posted on Aug 09, 2008
SOURCE: Sync iphone to outlook
I noticed this problem after the latest iphone update 2.1. It appeared that any events I entered on my iphone would not sync (transfer) to Outlook. However, it worked fine the other way (Outlook to iphone). What I finally noticed is that in Outlook, there is now two calendars under My Calendars: Outlook and Outlook Calendar. If I click Outlook Calendar, all the events I entered on my iphone appears on a seperate calendar. I don't know why there are two now, and it doesn't appear they can be merged. However, if I just use "calendar" instead of "Outlook calendar" when I enter events on my iphone, everything works and is on one calendar in Outlook. I don't know if that was unique to my case or if it will help anyone else.
Posted on Sep 15, 2008
SOURCE: Iphone sync with Outlook 2003
i want my emails from my Outlook 03 to wireless sync with my iphone
Posted on Sep 20, 2008
Syncing my iPhone 5s with outlook 2007 and vise versa
Go to the Microsoft support site the instruction are there.
Jun 01, 2016 | Cell Phones
Want to synchronize my Ipone 4s with gmail
Download google sync and that will sync contacts calendar and notes to outlook and when you sync with iTunes it should copy from outlook. You might have to select outlook as a source in iTunes though.
Sep 08, 2012 | Apple iPhone Smartphone
I want to switch computers when synching my IPHONE
This is the best two simple to follow but
graphical procedure you can use to effectively switch between one iPhone and 2 computers.
One iPhone, 2 Computers Sync Solutions
And just in case you may have any issues with the syncing of data from Outlook 2003, Apple has provided a support link should you run into any issue during your sync process with your iPhone to either computers due to a possible error with the .PST file.
Syncing iPhone with Outlook via iTunes
For more extra features for syncing your iPhone with
any computer, I also have one of my favorite articles:
Sync your iPhone with Any computer
I am providing this reference to you as a supplemental reference
Regards,
-Mactechtrainer
Nov 02, 2009 | Apple iPhone Smartphone
Sync iphone to outlook contacts
Speaking of syncing iPhone with Outlook, you can take advantage of iTunes to sync contacts. sync-iphone-outlook-contacts-oxaxc0rwhkhzilrwacqreyis-3-0.jpg
  1. Connect iPhone to computer with USB cable, and launch iTunes.
  2. Click iPhone icon, and choose Info the Summary Panel in left sidebar.
  3. Check Sync Contacts with, and choose in the drop-down menu.
  4. Click Apply at the right bottom to start syncing iPhone contacts with Outlook.
When the sync is finished, the contacts will show up in the Outlook contacts. Besides syncing contacts, you can also sync iPhone calendars and mails to outlook as well. But if you have noticed, the sync of iTunes is an annoying issue among iPhone users as during the sync of iTunes, the application may erase the available files in their iPhone.
http://www.leawo.org/tutorial/how-to-sync-iphone-with-outlook.html
Jul 19, 2009 | Apple iPhone Smartphone
How to transfer Contacts in iPhone to Outlook
Once your iPhone is connected to your PC and iTunes is loaded you can right click on your iPhone and select exactly what you want to have sync'd.
1. Under the Info tab you will find Contacts. 2. Tick the "Sync contacts with :" and select Outlook from the list. 3. Click "All contacts"
If you wish to put all of your iPhone created contacts into a different group in Outlook you can select the group there also and tick the relevant box.
iTunes always displays a warning about over writing data but that is not relevant to Contacts. Data is always merged.
I hope this solves your problem.
Chris
Apr 08, 2009 | Apple iPhone Smartphone
Syncing iPhone contacts and emal addresses with outlook
add me to your msn and i will talk you through everything.
add me Rightpricedelectrical@googlemail.com
regards nick
Dec 12, 2008 | Apple iPhone Smartphone
Sync Iphone with outlook
just install itunes and you can sync calendar and contact to your iphone. You cannot sync the notes and tasks but. I have just bought an iphone and before I was using an HP ipaq like you. Everything is synced except for the notes and tasks. You cannot even see any word or excel files you had on your ipaq. Cheers
Aug 21, 2008 | Apple iPhone Smartphone
Apr 24, 2008 | Apple iPhone Smartphone
How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
Jan 30, 2008 | Apple iPhone Smartphone
IPhone and Corporate Outlook synce
Try using MobileMe. It will sync your Outlook Contacts and Calendar but not your email wirelessly.You'll have to setup some sort of IMAP or Exchange server to sync your email.
Nov 26, 2007 | Apple iPhone Smartphone
Apple iPhone 3G Logo
154 people viewed this question
Top Apple Cell Phones Experts
Lesley Cameron
Lesley Cameron
Ed Nelson
Ed Nelson
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
