Question about Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Karaoke Player
While connected via VGA cable Viewsonic VG920 Monitor has an error stating "out of Range" . H. Frequency 157 Khz V. Frequency 59.8 Khz
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory set to connect directly to a television with supplied RCA cable. Do that before you connect to a VGA monitor. Using the remote control, press setup and then go into "preferences" and look around for "video" and then to "VGA". Once you click "VGA" the TV screen goes frighteningly blank. The next obvious step is to hook it to the VGA cable and VGA monitor. If your computer is also hooked up and on to the monitor there is no karaoke picture. Shut off or disconnect computer and presto, there it is. <br>
www.texsax.com
Posted on Dec 14, 2008
I get a message out of range.
your resolution is set too high.. change to VGA and move out from there. if the computer is set too high and you can not see boot into safe mode which should be VGA and set accordingly.
Nov 06, 2013 | Envision G22LWK 22" LCD Monitor
I am attempting to use a Viewsonic VX2235wm 22 inch LCD monitor with my Alienware m11x Rx2 laptop. (4g DDR3, Core i3 520um, Windows 7 64-bit) as an extension ofn my desktop. Naturally I would like to use...
Does it do the same if you hook it up to the desk top PC?
Common problem in this VX series are due to bad DC filter caps which can cause a lot of starnge symptom, see pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
The power supply may not be stable enough to handle higher resolution mode.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | ViewSonic VX2235WM Monitor
I have a ViewSonic VG920 that if you turn it off and back on the display is fine for about 2 seconds and then goes black you can do this over and over
More likely to have bad DC filter caps just like the rest of failed VIEWSONIC as shown in my albums here, VG720 is similar to VG920.
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 01, 2010 | ViewSonic VG920 19" LCD Monitor
My monitor says "out of range" H. frequency: 96.4 Khz V. frequency: 119.6 hz
You have to configure your monitor turn it down the frequency of your monitor range
Jan 07, 2010 | Office Equipment & Supplies
Sonicview VG 2021 - Out of Range message
..hi..just select menu on the front panel of LCD the find the option Auto then click Auto..good luck..Thanks...^_^
May 11, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Can VP171s work with Windows 95?
Your video settings are incorrect for the monitor. Right click on desk top and go into the settings/advance area where you can make monitor adjustments.re resolution and refresh rates.
Mar 29, 2017 | ViewSonic VP171s 17" LCD Monitor
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
A_turkovsky@yahoo.com
ya u enable vga mode hit f8 at start up in xp select vga mode ok resets u then use 60 hertz man and its native res ok only update drivers ect mark me ask fit ya ok thx nick
Feb 08, 2008 | ViewSonic VX1935wm LCD Monitor
H.V. frequency over range
I have a philips 105s5 crt monitor.First problem is vertical dead.Replaced this ic .Power ok but screen appear" H.V frequency over range" .How to solve this problem.Please suggest me.
Dec 23, 2006 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Karaoke Player Logo
519 people viewed this question
Top Cavs Audio Players & Recorders Experts
janman
da surgen
Don A
Don A
Are you a Cavs Audio Player and Recorder Expert? Answer questions, earn points and help others
