Question about Kenmore 94812 Top Load Stacked Washer / Dryer
Kenmore Laundry Center 94812 / 94814 drum problem
My unit is popping the feed (mains) breaker while drying on any heat setting. The belt looks very good and the motor turns freely but the drum seems to resist turning by hand, so I'd like to check the bearing and felt drum seals. Can anyone offer me some disassembly instructions so I can get to these parts? Any other troubleshooting suggestions would also be appreciated. Thanks!
5 Suggested Answers
SOURCE:
SOURCE: KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Posted on Dec 30, 2006
aborcass
  • 2651 Answers
SOURCE: Kenmore/Whirlpool 417.99170120 Laundry Center
5303281153 comlete rear bearing kit, should come complete with insrtuction's
Posted on Mar 10, 2008
blueextc3221
  • 15935 Answers
SOURCE: the drum on our lady kenmore washing machine will not spin.
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore laundry center stacked washer/dryer washer
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Posted on Sep 17, 2010
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 30, 2015 | Roper REX3614KW Electric Dryer
My dryer drum has stopped turning, is the belt easy to replace?
I would say replacing a dryer belt is a task of medium difficulty,
Loosen top -- it may pop up or you may have to remove two screws.
Remove 2-4 screws holding front of cabinet.
You'll then see the belt. There should be a diagram showing the routing of the belt around the motor, pulleys, and tensioner.
Here's a link covering a lot of the detail ::
http://www.diynetwork.com/how-to/how-to-replace-a-dryer-belt/index.html
Charlie
Jan 11, 2011 | Kenmore Dryers
My dryer heats up but is not drying my laundry.. What's wrong?
here is a fuw things to check first,,,, is the vents clear the dryer need to breath freely,,,is the drum turning around freely and not sticking due to belt slip,,, how dry are the cloths going ino the dryer,,,,(as the winer is here the air going in is cooler so takes more heat to warm it up) uk temp -2 degrees??? cold! how much are you putting in it? can it tumble freely,,,(no big knots in it?) try turning the heat up to full heat? and drying for longer,,,if all that fails,,,dont do any more washing??
Nov 28, 2010 | Kenmore Dryers
Kenmore Dryer Model #68202 just quit working. Set
Hi and welcome to FixYa. I am Kelly
Things that will cause a dryer to just up and stop are:
1. Door switch
2. Motor Switch
3. Belt switch
The first thing to check is the door...
a. Verify the door remains closed and that if you gently tug on the door that it does NOT make the door switch click. Things like the switch actuation post get worn and clothes being dried press against the door and can cause the dryer to stop.
The second thing to check is the drum.
a. Reach inside the dryer and push the drum in either direction. If it moves easily with little resistance (Belt not turning the motor as drum is moved) then the belt has broken and the belt saftey switch has been activated causing the dryer to appear dead in all aspects.
The last thing that can cause it to just stop is a failure of the motor or motor switch. (Least suspects at this time)
Also go to the main Circuit breaker panel and physically turn off the dryer 30A Circuit breakers by pushing them against the off position and then back to the on position. This resets the breaker completely
You did not mention the age of this Dryer yet at this time I suspect a broken belt has tripped the belt safety switch.
Thanks for using FixYa!
Kelly
Mar 03, 2010 | Dryers
Dryer keeps popping circuit breaker
either the dryer drum motor is getting tight from dry end bearings or the heating element is shorted to the dryer case or check the input terminals where power enters the unit,sometimes these ends burn off from current draw over time
Feb 02, 2010 | Dryers
Our Kenmore Laundry Center makes a small squealing noise, and proceeds to get worse the longer the dryer goes on, it gets to the point where I can not even stay in the laundry room. Please Help
Your dryer has either a bad belt pulley or a bad roller. You will need to pull the drum out and look inside the cabinet. There are two rollers that the drum rides on and the pulley is close to one of them. It take the slack out of the belt. I would go ahead and change both the rollers and pulley seeing your at them because these stack units are not that easy to work on.
2162268t.jpgHere is what the rollers look like
383724t.jpgThis is the idler pulley
Get your model number and go to this site.
http://www.partselect.com/ and then enter your model number. They will have every thing you will need. even a diagram to help. You can buy the parts over the net with a card.
Please rate solution if it is helpful
Aug 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Need to get into dryer to check heating element unit does not heat up all else seems ok model no. MDE9316AYW 5600 watts...help rubenandyolie
Check the house electrical panel dryer breakers (pair), push OFF, then ON. If breakers trip again, problem is a short inside the dryer. Pull the power plug from the socket. The top must be opened which allows access to front panel screws from inside. Lift the panel and pull away from cabinet. Disconnect the wiring to door switch and light. Make a diagram of wiring colors and where they went. Uncouple the drive belt from the motor--go through a sub-panel in the back and release a large tension spring from the idler pulley, then remove belt from motor. Remove several screws from inside of drum center, then lift the drum from the case. The heating element(s) are mounted in back of the drum on a supporting wall. Look for any burned areas or wires that touch the surrounding metal. On reassembly, check the condition of the drum belt--any cracks or missing pieces--replace the belt now.
Aug 01, 2009 | Dryers
Motor runs, but no heat generated.
It is most likely the heating element or thermal cut out. That is behind the drum. Remove the front panel. Get to the back panel. take it off. then notice how the belt is. draw if you have to. pop it off. then get gloves on the next step is very sharp and i will be the first to tell you.. you can go to the hospital... anyhow grab the back of the drum and the front then **** up. then you will see heating element and thermostats. you may see the heating element bad, if not then having the unit still unplugged check continuity on the fuses. call me if need any parts or more help. Here
Apr 26, 2009 | Dryers
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Drum is not turning. Heat works
Sounds like the belt has broken or come off. This is usually inexpensive to fix. You just need to get it out in the open to replace.
May 25, 2008 | Asko T761 Electric Dryer
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
152 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
