Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 3200 recognized but not accessible
It knows a usb device is connected, the drive light is on and there is a small amount of drive activity, but it doesn't show up. when i try to safely remove it, the safely remove hardware util won't come up unless i unplug the device. tried deleting driver, but won't install until i remove device. have about 180gb of data i'd REALLY like back.
  • amishownsyou Dec 13, 2008
    i cracked the case open... realized there was a short on the board that the drive connects to, so i threw it in the tower. it is now recognized, however it says that it has no drivespace whatsoever... either used or unused. it is apparently a 0 byte drive. i'm thinking it might have been fried when the board went. any possible way to recover???
  • Purple Sage Dec 31, 2008
    Any comments on a fix for this out there?
worldvet
  • 859 Answers
SOURCE: Computer does not recognize Maxtor OneTouch
Sounds like you need to remove the cable, uninstall the software, Restart, and then shut down. Now, from a cold power off power on. I know this seems tedious, but it has to do with the Last Known Good Recovery File and what is in Device Manger.
Now reinstall the software and if the software should call for you to "now" connect the USB cable, do so only when prompted or when the installer is done. Re: the latter, attach the cable. Windows ill say it discovered new hardware, point windows to your CD drive where the installer disk is located and allow Windows to locate the software.
Shut down and restart and your drive should be recognized now when you have a desktop. If not, post this back using the comment box below.
When replying to mine or anyone else's reply please address us in your reply, such as Worldvet: that doesn't make sense, please explain. And so on and so forth. This allow US to track what you've tried and from whom you were provided the solution.
Thank you for you indulgence on this. And, please be aware that, we all here want to see you fixed up and on your way. We all have a pretty good track record. However, there are times when a repair from a warranty service center is the only solution. However, I'm certain we all can get you taken care of and thanks for using Fix Ya.
Regards,
Worldvet
Posted on Aug 06, 2008
  • 6 Answers
SOURCE: Maxtor 3200 backup drive not recognized in my computer to access
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=510
Re: whishels
Options Options
eltigre
New Visitor
eltigre
Message 23 of 61
Viewed 3,676 times
My Maxtor 3200 died also. I took the following steps to get it running again.
(1) Remove plastic box from around unit. Carefully stick a screwdrive in the case division and pry it apart. It is not easy, but do will finally come apart.
(2) inside you will find a perforated metal box. There are two screw on each side of the box. Remove and separate the two halves.
(3) there you will discover that inside is just an ordinary Maxtor hard drive like you would buy in the electronics store. Attached to the HD is a PC board. There are 3 screws holding the PC board down. Remove the screws and carefully remove the HD and PC board.
(4) unplug the powere plug and the IDE interface from the HD. Now you have a HD that you can install in your own case (as long as you have a desktop unit and not a laptop).
(5) I installed the HD in an empty slot, connected the IDE cable that was already there (between the CD and IDE interface), plugged in the power plug, fired 'er up, and voila, works like a champ.
I suspect that the problem is in the interface (PC board), since the only thing I did was remove that from the equation. Hope this helps
Kudos! Thanks!
09-09-2008 09:36 AM
Posted on Feb 14, 2009
SOURCE: maxtor 3200 usb personal storage
Like many others, I had problems with the drive and tried some obvious solutions like swapping the old USB cable with a new one, trying different computers with XP, Vista, etc. and nothing worked. One solution I found was to open the HD case and swap the drive into a spare bay on your PC tower. I didn't want to go there since the case is very hard to open and I didn't want the hassle. So, the solution I tried was to replace the power supply. I saw this solution a few times in some forums so I figured to give it a try. I Googled the exact specs and found a comparable power supply at 12V Adapters (Aurora CO). It is not a Maxtor supply but I figured as long as the output was correct it may work. Just got the adapter today, plugged in the HD, and YES, IT POWERS UP and the XP at my work recognizes the drive! Now I have all my files available and accessible. Good luck to all, I hope this works for you. By the way, one lesson learned: BACK UP BACK UP BACK UP! Drives are so cheap now there is no reason not to (except for being lazy)!
Posted on Apr 17, 2009
Geekman
  • 32281 Answers
SOURCE: Maxtor 3200
Try connecting the Maxtor to another computer and if it functions normally, then backup your data. Then try formating the Maxtor on your computer.
Posted on Sep 08, 2009
edwin270
  • 308 Answers
SOURCE: i can not see my usb maxtor 3200 hard drive in my
this could idicate a low power supply for the device. some computer do have front usb ports, the truth about this front port is that they lack the power to supply some of this devices (being 200GB). If you are connecting it to the front usb then try using the main one behind the pc.
also note that usb polling which acts by reducing power consumed by the device may also be a cause(that is if you are using a modified version of windows other than that from microsoft since the modifier can alter that as well). Also try using it on a friends pc to see the outcome.
do let me know of the out come.
good luck
Posted on Jul 04, 2010
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
My laptop no longer recognizes my external hard drive. Device Manager gives me an error code 10.
Connect the Maxtor to a different computer, to see if the device works in some other computer.
If the warranty is still valid, exercise the warranty to get a replacement.
If the warranty has expired, disassemble the casing, and disconnect the USB-to-disk-drive interface from the disk-drive.
Connect the disk-drive as a "slave" disk-drive in some other computer, to see if the USB-to-disk-drive interface is the part that failed.
If all else fails, search online for commercial "data recovery services" -- for a large amount of money, they will disassemble the disk-drive, repair it, just long-enough to copy your files.
Aug 09, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I can not see my usb maxtor 3200 hard drive in my
good luck
Jul 04, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 300 gig. Drive is not recognized via
reboot the laptop, reseat the cables, and try connecting the drive to different usb port. if that still doesn't work, most likely the drive has gone bad.
Oct 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Computer suddenly does not recognize my external drive
I assume you have look at the Microsoft Knowledgebase article?
You can also check this troubleshooting article.
You might need to force reinstallation of some devices, the external HDD at least, but maybe also the USB controller device in the Device Manager.
Worst case scenario, open the disk and connect the HDD internally (IDE/SATA depending on the interface).
Jules
Mar 02, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 usb hard drive with windows vista home premium
Hey guys I had the same problem... All the drivers for the device are inside the harddrive. Maxtor doesn't have any because you don't need any. What they've neglected to let any of us know is the power supply provided with the unit isn't powerful enough to run it. Replace the original power supply with another one and this will solve the problem. I replaced mine with an old laptops power supply, the fit was alittle tight but believe me it works.
Jan 29, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor and vista
Try some other USB device (memory-stick, printer, camera) in the USB slot in the Vista computer, just to "prove" that Vista will recognize _any_ USB device connected to that slot.
May 31, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
61 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
